RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Any mounting strap tips? (https://www.rcuniverse.com/forum/rc-jets-120/4315319-any-mounting-strap-tips.html)
viper1 05-25-2006 01:01 PM
1 Attachment(s)
During a inspection I found that my turbine has moved slightly forward within the mounting straps (only about 3 mm)
It can't come out as various screws on both sides of the straps will hold it anyway. But I don't like the idea (shifting C of G etc)
I'm using the black (heat resistant?) double sided tape between the straps and outer case as per mounting instructions.
It feels rock solid but the tape must get soft when hot or warm.
Any tips to prevent this?
Thanks in advance!
http://image.rcuniverse.com/forum/up...82/Hf99958.jpg
DaveMatthews 05-25-2006 01:18 PM
RE: Any mounting strap tips?
Get this . . . Can't be beaten.
http://mickreevesmodels.mysite.wanad...o.uk/strap.jpg
JETSTRAP £15 UK pounds
Instant release steel strap mounting.
Remove turbine from model in 10 seconds.
NOW IN STOCK in KJ66 size or MW54 size
at http://www.mickreevesmodels.co.uk/ under jets and jet accsesories . . . . . . .
j.duncker 05-26-2006 03:17 AM
Had the same thing happen to me the first time I ran up my Wren. An official brown trouser moment.
I got some 400 grade wet and dry, cut it into strips, glued it to the inside of the straps and that has fixed the problem.
jeff sewell 05-26-2006 03:53 AM
I used a jet strap on a 30 pounds thrust motor. Not recommended though as I had to get the strap so tight on the motor to stop movement that it began to deform the release latches.
Aside from that I think its a really good product.
I have glued thin leather to the inside of other 'normal' straps and have found this to adequate.
Jeff
digitech 05-26-2006 05:10 AM
ORIGINAL: Davie M
if you need to remove the turbine so fast and that much maybe its not the straps you need....:D
lugebob 05-26-2006 09:13 AM
I have had the P200 slip so far forward on the Jet Luge (toward my head [X(]) that the only thing keeping it from going further was the glowplug. I found that with all the heating, cooling and stress the straps actually stretched a little. I wished the JetCats had a little more contained mounting system, like indentations formed on the case, but they don't. I ended up using strips of cut-up beer can as shims to take up the space. (finally... a good use for Budwieser). Also, just to make me feel better about what was happening behind my head, I put "teeth" on the straps by knurling the contact surface. The first one I scored a cross hatch pattern with a razor, the new one I rolled with a knurling tool.
bob
viper1 05-26-2006 06:40 PM
All the things you can learn !!
I never heard of a "Jet Luge" [sm=surprised.gif] , but now I can add that to my vocabulary,
same for the "brown trouser moment" (although I had many of them in the past..:D)
Thanks guys, I like the leather option as well as the sandpaper, just wouldn't like to scratch my expensive toy.
I think I know where to go from here.
Thanks all for your input!
GJ
http://people.aapt.net.au/gjmustang/.../turb_back.jpg
