bauer fans (help?)
can any one give me info on bauer fans i have a pair of 6inch fans (thought they were byron) 6 blades with rossi 90s and shrouds i need to find out what sort or thrust and what rpm ,are thease low reving fans any help would be great
bauer fans (help?)
Can you post pictures? I'd like to see what they look like.
Byron fans are, as far as I know, all 5 blade. JA |
bauer fans (help?)
1 Attachment(s)
here's a pic of the fans
bauer fans (help?)
hi there these look like gleichiev fans not sure about the spelling ,think they are german seen something simular in old mag ,from the kit maker long time ago they made f16 before Byron
bauer fans (help?)
Pretty sure they are Gleichauf. I had a pair, but I did not use them. I was TOLD(which is not the same as personal experience) that they were the same as Byron fans, maybe a little more efficient, thrust and revs should be very much like Byron.
I HEARD, also, that their F16 was a knockoff of the byron, and flew just the same. If you are building a twin, I suggest you set up a test bench and check out those R90s...me, personally, would not feel good about the reliability of those, particularly in a pair. |
| All times are GMT -8. The time now is 01:45 AM. |
