this is a good one!!!
ok here is your chanse to make fun of me big time!!:):)
.....[&:].how you can fint out if a kero has turbine oil in it???[&:] ......i have a big tank with kerozin and i dont rememper if i had placed turbine oil in:D:D:D:D ..... should i add again and fly with 10% at worst case?or i will expirience any flyght problems????[:o] ....thanx in advance for any ideas... sorry for the bad english:eek: |
RE: this is a good one!!!
taste it ...
Voy |
Put some clear fresh kerosene in a clear glass container and then your unknown sample in another. Place both in the sun for 1 hour. You will see the oil / kerosene mix turn a darker color ( straw / amber ). Clear unmixed kerosene will remain clear.
Regards Dean Wichmann www.pstna.com |
Evaporate it and see if oil remains ?
taste it
voj your priceless vinny |
did he say taste it? i think he meant drink it! if it makes you sick there is a 50% chance it has turbine oil in it
hope this helps m |
please any one of you is a doctor?
i would like to know what the symptoms are if you drink turbine oil.....i gaved some to my wifes mother...and she still walks...#$%^&*()(*^%[:@] |
OK...here is the deal.
Have your mother-in-law drink a quart of it. Wait 30 minutes and then have her belch while you hold a match to her mouth. If the flame is blue, it is oil free. If the flame is red and gives off thick, black smoke it has oil in it and is safe for your turbine. See, it's so simple. Beave [8D] ORIGINAL: DelGatoGrande please any one of you is a doctor? i would like to know what the symptoms are if you drink turbine oil.....i gaved some to my wifes mother...and she still walks...#$%^&*()(*^%[:@] |
Give fresh Kerosine to your wife and a glass of unknown to the mother in law wait 20 mins,then watch them carefully, when they start to run about watch and see which one seizes up and crashes use the other fluid in your tubine this contains oil.. How ever if they both stop at the same time they have run out of fuel and need a c135 to give them air to air refuelling if this cannot be called in, wait for them to crash and burn, no more problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The best thing is the 2x glasses kerosine and oil will go brown in sun light. Good luck. MH |
If I'm unsure about whether I've put in the oil, I let my buddy try my fuel. If he gets a whole flight in, it's good to go!!!:D
ORIGINAL: warbird51 If I'm unsure about whether I've put in the oil, I let my buddy try my fuel. If he gets a whole flight in, it's good to go!!!:D u r mean!!!:) |
Well, you should see the guys I fly with!!![sm=cool.gif]
| All times are GMT -8. The time now is 06:22 AM. |
