Experimental turbine
In college a few years ago, we had to come up with / engineer the most efficient electricity creating energy plant. We ended up building a 12inch tube and used combustion to spin a small turbine, connected to a shaft which spun an electric morot; creating around 950watts of energy. In this experiment we used Propane and Oxygen tanks. We, by far did not use much propane/oxygen to create this amount of power. The only drawbacks were the heat created (EXTREME) and the bursting startup flame (pretty cool).
I am thinking about trying this out; http://img.photobucket.com/albums/v5.../turbine-1.gif Instead of powering an electric engine, I could power a fan... I can built it and bring it to the lab eventually, maybe I can achieve around 1500 to 3000 watts with a good compressing O/P shaft... |
RE: Experimental turbine
How do you keep the combustion chamber from melting? Active cooling? What's the max temp?
how do you cool and lubricate the bearings ?
I don´t think the AMA or other authorities will be too happy of transporting O² bottles in modeljets......:D
Regards, Gerald |
This is just a very gross draft of the actual engine;
Cooling; With a mix of approx 2:1 (oxy:propane), heat is directly proportional to the work (kjules). So the more power produced, the more liquid needed. We went with a 2:1 ratio for coolant vs combustion chamber volume. I was just thinking about this: http://img.photobucket.com/albums/v5...8/turbine2.jpg The rib patterned rad could also act as a stator... |
Have a fire extinghuisher to hand..:)...like i allways do..[:@]..:) |
As for bearings, I could use 0W50 oil going through a small pump (2-5 psi depending on RPM). Havent thought that far ahead yet lol... I guess im going back to the drawing board...
I'll try to build it this weekend... Does anyone know where I can find high compression turbines? THanks |
Should we call the ambulance now?[X(]
come on guys help this guy dream,,you never know it might be the next RC jet engine???
I agree that we should not belittle any experimentation and that this guy should be encouraged to experiment, but I doubt this particular idea will yield anything useful for the masses. I get a feeling that the amount of propane required for a ten minute flight will be like the old JPX days (with a very heavy tank) and then you have the dangers of pure LO2 and another heavy tank. Seems an order of magnitude easier and more practical to fly one of our existing turbines, not to even mention the safety issues of LOX!!!
true but dont down the guy
ORIGINAL: littlepiston true but dont down the guy |
Just make sure to get some Video of it and post it back here.
Gene |
fine the guy is nuts :D
ORIGINAL: littlepiston fine the guy is nuts :D Jackjet |
| All times are GMT -8. The time now is 01:55 PM. |
