F-4 Lights
First of all Happy Hogmany to everybody!!!!
Do any of you guy's know where the bottom anti-collision light is positioned on a Phantom. I've got a nice set of mini strobes waiting to be fitted to mine. Ta very much Dave |
F-4 Lights
I don't think there is a strobe on the bottom of the F-4. I did just pull out some pictures of the "E" model that I modeled, and the lights on the bottom are as follows. Landing lights, 1 mounted in the nose gear door, one attached to the nose strut. One on each side of the airplane directly under the intakes approximatey 4-5 feet back from the front of the inlet. There is one more light on the starboard side toward the leading edge of the vertical stab about 1/2 way down the side of the fuselage. (Top to bottom) There is one at the top of the vertical stab at the trailing edge. The colored lights are at the wingtips, how they are arranged at the wingtips is dependant upon which model, and what modification the wingtip follows. I have quite a bit of documentation on the F-4 if you could give me the model (B,C,D,E...etc...) I can look at some more pics for you.
David Reid |
F-4 Lights
Thanks David, I think you pretty much answered the question. Now I know who to ask all my 'Rhino' questions.
Cheers Dave |
| All times are GMT -8. The time now is 12:59 PM. |
