RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   vampire questions (https://www.rcuniverse.com/forum/rc-jets-120/4548782-vampire-questions.html)
eagledancer 07-26-2006 07:20 PM
vampire questions
hey guys, hope someone can lead me a bit, i am new to jets (20 years in rc aircraft tho) i just aquired a set of plans for a vampire that has been enlarged to 80" span, i figured this would be a good one to start with, should be stable, ect. would like to go ducted fan (the cost of turbines is a bit much for me as a entry level) i would like to know what engine/fan would be right for this one
thx guys
eagledancer 07-28-2006 07:39 PM
RE: vampire questions
hey guys, this post has had alot of readers but no replys, i wont hold a gun to your head if it dont work out, just need a bit of guidance.
i am thinking all up weight will be right around 20-22 lbs, would a .90 fly it, which engines work out the best, which fan, do i need ducting? just give me your gut thoughts on it. i am very experanced at building and do alot of scratching.
Wayne22 07-28-2006 08:56 PM
Probaly the best person to talk to would be Kerry Sterner..He is the Vampire guru! :D
rcjet lynch 07-28-2006 09:04 PM
Given the size of the inlets on the plane I would probably say Viofan and .96 if you can find one very reliable and strong might be something to look into
Vampire 08-01-2006 08:31 AM
1 Attachment(s)
eagledancer,
I also offer a 1/6th scale Vampire plans and parts set which is 80". I can tell you that your guess of the finished weight of 20-22# is a good estimate and I would suspect it to be closer to 18-20#.
I do offer laser cut wood sets for the 1/6th Vamp and have them in stock as well as Canopies and F/G inlets.
I have had no-one convert one of my Vampires to Elec. D/F so I cannot be of any help except to say that the Vampire has a very generous wing area.
Please conact me if you have fruther questions.
Kerry J Sterner
610-746-9444
F86_SABRE 08-01-2006 10:55 AM
Highly likely that the design lends itself to be a good flyer, however, I can vouch for Kerry's Vampire because a friend of mine has built the larger version of it and the plane is a dream to see it fly. Very steady and not ballistic....a real scale model.
Recommended!
Reuben
