RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   FUTURE ON CANOPY'S---Wow (https://www.rcuniverse.com/forum/rc-jets-120/504337-future-canopys-wow.html)
WhoDaMan 01-24-2003 01:08 AM
Ok guy's:
I took my extra Yellow F-18 canopy and wiped it down with future floor wax, and oh my god I cannot believe the difference in the finish. It is like diamond hard finish but not brittle at all. I know that modeler's have been using it for years. Has anyone tryed this. It says no yellowing. I would like to post the shots if someone would like to post it. I could forward it to you.
Thanks, Dave R
ishu4u 01-24-2003 01:34 AM
hush now that is top secret.. toledo show check list thing you know....it makes winners out of a many fine planes..
PR38 01-24-2003 02:24 AM
yea, ssshhhhhh!
That was my secret too
igoren 01-26-2003 03:21 AM
future floor wax
hi
where can i get this product?
thanks
isaac
[email protected]
WhoDaMan 01-26-2003 05:15 AM
Future
Any longs drug store
Dave
Modelman 01-26-2003 03:32 PM
Another Future Secret.
The results are mour spectacular if you dip your canopy instead of wiping it.
The Cat's outa the bag!
Craig
igoren 01-26-2003 06:44 PM
future floor wax
hi
can any post a pic of the product ,future floor wax
i can not find anything on the net,and on longs drug store site
item not found
please help
thanks
isaac
[email protected]
ghost_rider 01-26-2003 07:31 PM
A quick google search shows
http://www.cornerhardware.com/db-ima...001826.pre.jpg
Also take a look at: http://acmeclub.topcities.com/Future.htm for more information on Future Floor Wax Uses
747drvr 01-26-2003 10:06 PM
Hi Guys,
Do you wipe it on after installation or before? Does it effect the gluing at all ?
WhoDaMan 01-26-2003 10:49 PM
Future
It will not affect the gluing, and unless you have a lot of it to dip the whole canopy in you will need to wipe it on,and yes do it before, I have found that if you will make clean sweeps from one end of the canopy to the other in one direction works well, also use a dust clean cloth or you will leave specks in the clear coat. It makes it very hard to scratch once applied. Also do not panic if you blow it. It can be removed by the solution they give you on the back. Don't hold me to that but they say it can. Like the old master say , Practice, Practice, Practice.
I think it looks sweet when done, and thanks Ghost Rider for the page.
Dave R
Countryboy 01-27-2003 05:47 AM
The Future "Before & After"
1 Attachment(s)
Here you go Dave. What a difference the future makes.
747drvr 01-27-2003 11:59 AM
A few more questions. Do you apply to inside and outside surfaces and does it wear off ?
WhoDaMan 01-27-2003 02:12 PM
Thanks Ronnie
Thank you CountryBoy:
747, I apply it to both sides, I do not know the long time affects of the product. I do not see why it would wear off.
Dave R
Topgun2mo 01-27-2003 03:02 PM
Suppose you were painting a molded in frame? Would you just abraid the area that will be painted after dipping/brushing?
Mike
WhoDaMan 01-27-2003 03:47 PM
Future
Hi Mike:
I think that would be fine. Tape off the area to keep clean. I glued the whole thing to my frame. That was last night. I used canopy glue and this morning I have a good bond
Dave R
BlueBus320 01-27-2003 10:22 PM
Have any of you guys tinted your canopies with RIT dye and then applied this stuff ? if so, did it bother the tint ?
Woketman 01-27-2003 11:17 PM
Or maybe put food coloring in the Future? Will that last?
WhoDaMan 01-28-2003 12:49 AM
Jermaine Future
Hi Heliboy:
I think since the color dye is in the plastic that a coat of future would hold it there. What ever you do do not mix it with water, it turns it a milky white.
Dave R
DF_Flyer 01-28-2003 01:29 AM
Can anyone tell me what SNJ powder is? Number 10 on the link Ben provided talks about using SNJ powder and Future for a rock hard gloss silver finish.
DFF
six shooter 01-28-2003 02:14 AM
Find out about SNJ here
http://www.snjmodelproducts.com/
fred cesquim 01-28-2003 12:29 PM
Hello mates!
this one i learnt(along a lot of more usefull information) reading fine scale models:
glue your canopy to the airframe, sand with 2000 grit wet sandpaper(donīt worry!!) then mask the airframe and airbrush future over the clear!like magic you will have a cristal clear canopy without a scratch!if you have deep scratches, go withh 600 grit first, than with 1000 and finally with 2000, the scratch will disappear. as far as i know future last long(maybe 5 years) and as itīs an acrylic base iīts not affected by cleaning.
try and tell me!
see the link bellow tahtīs the canopy of a rafale that iīve built for a client 3 years back:
http://rcuniverse.com/attachment.php?s=&postid=159737
regards, fred
WhoDaMan 01-28-2003 01:57 PM
Fred Future
Thats awesome Fred thanks, ;)
Dave R
JoGiasson 02-19-2003 05:10 AM
Fred
when you airbrushed Future on the canopy-did you thin the Future down to make it flow thru the airbrush? If you did ,what did you use and to what ratio did you thin it to(2:1-3:1) or what ?
Tried to use the airbrush' but it was tooo thick to flow.
fred cesquim 02-19-2003 01:45 PM
i really canīt remember!!!!
i think that iīve used alchool or water, sorry, really canīt remember.
anyway, nowdays i use 2 part clear, it goes along when i clear shot the plane and itīs more durable, plus you have that awesome glass look!
aparchment 02-19-2003 03:59 PM
Canopy tricks
1 Attachment(s)
Here you go guys -- my Ultra Viper canopy after two coats of clear following sanding with 600 then 1000. Once that was done I waxed it with Zymol, though I am sure any good wax would have been fine. The only problem is that now it is so slippery I can hardly hold it without dropping it.
To tell you the truth I was tempted not to clear the canopy because after sanding with 1000 it had this cool brushed graphite look to it. It would have been very appropriate for the color scheme.
Antony
