Cheap and simple trainer
I am going to open a big can of worms here and ask what is the best trainer for turbine power (12 pound thrust). Looking for something cheap and simple. This will be my first turbine just want to keep it simple.
RE: Cheap and simple trainer
I would suggest either a baby boomerang or a facet, both are easy to build and fly.
Alan |
Reaction 54, Baby Boomerang.
A-10x.
Raf |
Thanks for the sugestions guys. How about something from plans? I have plenty of wood could use money saved for servos, brakes, ect. Shouls of said that in the first post.
from Plans the Facet 1200 would be the way to go
do a search for Kerry Sterner. he has the plans for the Facet 1200. you can also find kerry at Simjet USA Mark |
1 Attachment(s)
If you're into kit bashing I recommend an Enforcer. It might not be quite as simple as some of the pure trainers, but it's a lot more fun to fly and is cheap.
Below is a couple of pictures of my first turbine, which is still going strong after 145 flights. Also here's a link to my build thread http://www.rcuniverse.com/forum/m_24...nforcer/tm.htm Joe |
1 Attachment(s)
We would recommend the FACET -1200H/P
Excellent short grass field ops. Very simple construction Avail. from our distributor, Dreamworks R/C Brg. |
1 Attachment(s)
what about the super reaper.
[link=http://www.worldhobby.eu/katalog/Jetpower_Kat_D_2006.pdf]Catalog[/link] |
The cheapest and simple plane is a Bobcat pusher for $129
converted to turbine(jet joe JJ1400 fixed gear), you can not buy glue, wood, covering that cheap. A new Jet Joe is around $800 with the manual ECU and flightwork pump and thermocouple costing about $300. You can use normal servos except the elevator where one JR DS821 will do. The plane is rock solid and easy, but super fast, to fly. See the article in this months RCJI. Johnny |
You might want to read the JetJoe thread before you plunk down your money.
If you're into building/rebuilding/modifying engines, then JJ is for you. If you want to just fly, you might want to look at other, more reliable engines. Good luck! |
http://www.x-tremejets.com/twe/image...images/2_0.jpg
I don't know how you can beat the x-treme jets A10x. It includes fuel Tank, Retracts- struts, Wheels, tires brakes, air valves, 2 air bottles, All for $595 |
That A-10X is hard to beat.
I'd stay away from Jetjoe. With all of the modifications and fixes required just to get one to start and run, I have zero confidence that one would ever make it to 25 hours. The Balsa USA kit retails for $111. The kit I used to make mine was bought at a swap meet for $40. I had to buy covering, retracts, wheels/brakes, and radio gear, and you do need some building skills to make the modifications. I don't have an exact total but after buying a used Ram 500 for $1000 I was able to build the Enforcer shown in post #8 for significantly under $2000. Joe |
Thanks for all the help lookig pretty serious at the jetmach.
| All times are GMT -8. The time now is 08:48 PM. |
