RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   FOD guard (https://www.rcuniverse.com/forum/rc-jets-120/521371-fod-guard.html)
Dennismate 01-30-2003 08:50 PM
FOD guard
Could you please settle an argument for me. I say that a FOD guard on a turbine does not have a detrimental effect on thrust/power but a friend of mine insists it does. Anyone with experience of using one please reply.
Chris Z 01-30-2003 09:03 PM
FOD guard
Stu,
your right.
It does not have a detrimental effect on thrust/power, tell your friend to keep flying props.
CZ
DavidR 01-30-2003 09:27 PM
FOD guard
That's the best laugh I have had all day....too funny!
Ehab 01-30-2003 11:01 PM
FOD guard
Your friend MAY be thinking of ducted fans and applying the same theory to turbines. The inlet of turbine is a low pressure zone and hence a FOD screen has minimum to no effect on our models. I flew my HS with and without FOD screen and recorded almost identical top speeds at Fresno jet meet last year!
Captainbob 01-30-2003 11:39 PM
fod screen
I can't comment on model turbines, however, fod screens are used on some full size applications and they do make a difference. Two examples i can think of off the top are the A-37 jet fighter made by Cessna and the HH53 chopper. In the case of the A-37 the screens are retractable.
GSR 01-31-2003 12:23 AM
FOD guard
One thing that you guys might be overlooking is the size of the mesh of the screen. A mesh size of 1/16 inch will probably not cause any degradation in airflow-OTOH a mesh size of 1/32 or smaller would. I have seen some tea strainers tha use a very small mesh size (between 1/64 and 1/32 inch). Only sure way is to test it with and without. Scott
Captain RIB 02-01-2003 10:28 PM
FOD guard
I have experience on 2 types which have FOD screens and both suffer around 8% degredation when they are used. One is the A37 Dragonfly (which has retractable screens) and the other is the S61 helicopter. The ones on the A37 are linked to the undercarriage and cover the inlets when the gear is lowered and there is weight on the wheels. (You can also lower them manually i.e. before a strafing pass). The S61 had FOD guards fitted for summer use only as they can ice up in the winter (as can those on the A37). Hope that this helps!
Lee Cox 02-02-2003 02:40 AM
F.O.D
So what do you guys make the screen from, I have a wren wm54 and have been thinking of making a mesh cover of some sorts!!!
Any ideas would be appreciated.....
Lee
F9F Texan 02-02-2003 04:50 AM
FOD guard
Lee 999
Check this recent thread on the subject.
Johnny
http://www.rcuniverse.com/showthread...893&forumid=26]
shonny 02-06-2003 04:08 AM
FOD guard
Originally posted by czonio
Stu,
your right.
CZ
. . . so long as the open area of the mesh is greater than the max aperture of the intake? :o
Jackjet 02-06-2003 04:49 AM
FOD guard
Pilots,
Yes- I would say it does have a definite effect on a model gas turbine - because the first time you ingest some FOD in your engine because you ran it without a screen - the thrust WILL be degraded and so will your bank account (if enough gets sucked in there).......moral of story - use SOME kind of screen to protect your engine....JMHO
Jackjet
CobraJet 02-06-2003 09:13 AM
Re: FOD guard
It can ruin your day if the screen ices up. :D
SimjetAU 02-06-2003 02:05 PM
FOD guard
Stu,
your right.
CZ
We call them "bug smashers" in the land down under :)
and yes i do still enjoy flying bug smashers too....
