Comp ARF Flash
I was in Motors and Rotors this morning, and they have 2 Flash kits for sale. What are peoples' views of this model, which I would power with a P80?
Roger |
RE: Comp ARF Flash
ORIGINAL: Roger M I was in Motors and Rotors this morning, and they have 2 Flash kits for sale. What are peoples' views of this model, which I would power with a P80? Roger you can find dave here also just as much as at the shop.....;) i think the combo is ok powered with a Wren supersport is better. (less weight , more power less fuel) but then for the price these p80,s going for you cant lose. the combo is ok.. |
RE: Comp ARF Flash
Hi Roger,
The combination would be fine. I have a mercury HP in mine and whist there is plenty of power for tarmac operations, if I was regularly flying off grass I would like a little more. At the last count 7 other club mates have flown mine and they all really liked the way it flew. In fact Roger if I remember correctly you are currently flying a Rookie? If so, then the Flash will be easier to fly! Geoff. |
RE: Comp ARF Flash
Geoff
You need more power...like someone else you know! Sandor, I've already told him its a great aeroplane... Dave |
RE: Comp ARF Flash
Hi Geoff,
You have a good memory - yes I'm flying a Rookie and I'm interested to hear that the Flash will land more easily, especially as last time out I thought I had nailed the Rookie's landings. It's all positive stuff so far. Roger |
RE: Comp ARF Flash
Roger,
I have a few flights on my P120 powered T'bird Flash now and can recommend the aeroplane. It all depends what you want from an R/C jet. If you are looking for a jet that is simple to put together on the field and looks and performs well, and is good value for money, then the Flash fits the bill. Not too sure about a P80 though, especially if you want to operate from a grass site - go for the P120 or 'just Booster it'! Cheers Rob |
RE: Comp ARF Flash
Rob
P80 is OK on grass-you just need 100m and our new legs regards Dave |
RE: Comp ARF Flash
Just out of interest Dave what colour are the flashes that you have in stock.
Martin |
RE: Comp ARF Flash
Mart
Am I allowed to say? red and a TB scheme. Dave |
RE: Comp ARF Flash
What do you mean by "new legs"
RE: Comp ARF Flash
Geh3
I was talking about trailing link main legs-just because they are easier on the gear and mounts. There are a couple of sets available For really smooth grass and a good length strip the std legs are fine Dw |
RE: Comp ARF Flash
Well on my first takeoff with my new FLASH I was about to rotate and the right 6mm pin shattered in my C_ARF supplied BEHOTEC langing gear and I had to abort. There was no damage to the plane but my heart rate is still slightly above normal. I was thinking that some softer wheels and/or some trailing link main struts (like JETA1) would be better on grass which here is always slightly rough
RE: Comp ARF Flash
ORIGINAL: Roger M I was in Motors and Rotors this morning, and they have 2 Flash kits for sale. What are peoples' views of this model, which I would power with a P80? Roger |
| All times are GMT -8. The time now is 08:25 AM. |
