RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   How to remove Jet-A1 fuel from the inside of ECU? (https://www.rcuniverse.com/forum/rc-jets-120/5683318-how-remove-jet-a1-fuel-inside-ecu.html)
Propellars 04-08-2007 10:13 AM
1 Attachment(s)
Hi there
I just noticed that I have som jet fuel in my ECU, and I´d like to remove it before it damages the electronic. But how? The print and some of the components are wet [:o]
rcguy! 04-08-2007 10:22 AM
RE: How to remove Jet-A1 fuel from the inside of ECU?
I suggest a gentle scrubbing with denatured alcohol. Check all plug-in pins and sockets for any residue.
Dave
Kevin Greene 04-08-2007 10:24 AM
Or you can clean the board with an electrical contact cleaner.... [sm=thumbs_up.gif]
Kevin
Propellars 04-08-2007 11:02 AM
Im brushing everything with denat. alcohol 3 times, with drying in between.
Is the fuel very damaging to the electronic?
bcovish 04-08-2007 12:31 PM
If you use the spray contact cleaner, make sure it says "leaves no residue" on the label.
