RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Flash with Crow Feedback (https://www.rcuniverse.com/forum/rc-jets-120/5764853-flash-crow-feedback.html)
jkeze 04-24-2007 07:01 PM
Just getting mine done and was looking for feedback about using crow with flaps. Good, bad or indiifferent.
Jack
HAMMERDOWN 04-24-2007 08:08 PM
RE: Flash with Crow Feedback
Not needed on this jet. No need to complicate things, this jet will land on a 300 foot runway using the flap setup in the manual.
BluFox 04-24-2007 08:15 PM
Jack:
Coming up on 50 flights with my Red Checkers Flash. Jet Central Falcon for power. No need to mix in crow on this jet. Factory settings are well tested and proven time and time again to be just about right on. I did reduce the full flap setting as in stronger winds, the reduced full flap setting works much better for me. As for CG (yes, I know you did not ask) make sure you stay within the range recommended. Balance forward for the first few flights then move it on back. You will find this jet to be a superb aerodynamic platform which is rock solid in flight. Enjoy!
Best regards,
Eric Clapp
Jet Central Artes Turbines
Lifetime Warranty
