Pics of Discovery Jet?
Hey Guys.
I'm about to begin construction of my Discovery Jet designed by Dick Sarpolus. If anyone out there has a Discovery Jet , I would greatly appriciate some detailed pics of equipment intallation, construction, and what ever else may be handy. Thanks Jeremy Smith |
RE: Pics of Discovery Jet?
Using the search function under the jets forum with "discovery" turned this up. Try it! http://www.rcuniverse.com/forum/m_56...tm.htm#5659791 Dave |
Jeremy I have built 4 of them what would you like to know?
Alan |
1 Attachment(s)
Mine flys great I have about 50 flight on it now. here is a pic
Hey Fellas.
Thanks for the replys. Ive got a few pics from JR in TX that show the initial framing of the fuse and initial construction of the wing. I'm thinking of purchasing a vacuum press from veneersupplies.com to bag the wing. Ive never scratch built from plans before. I'm just now to the point of tracing the plans and cutting out templates. However, I'd like to see equipment locations, mounting, harware ect. just to begin to get some ideas. Looks like you got retracts in the attached pic. What are you using? I plan on using a JC P-80 for power. I'm going to widen the rear of the fuse 1" to accomodate the P80. I was thinking of using a Dubro 50 oz tank with a 24oz up front and a UAT Servo will be Hitec 945 on the wing and Hitec 625 everywhere else. Planning on a 1800mAh 6volt with voltage regulator for power. What are you guys using?? Any suggestions?? Thanks Jeremy Smith |
| All times are GMT -8. The time now is 05:15 PM. |
