I4c Isolator...
Anyone used one...?...All O.K....? Do you have to use both Servo batt inputs ?...both switched i assume ?...And i assume that the RX batt is switched on the input side ? [sm=red_smile.gif] if i did have some instructions then i dont know where they have got too... Brg Dave. |
RE: I4c Isolator...
Hi Dave
I have been using them for a good time never any issues. The dual battery input does not have to be used only if you want a back up or more power to your servos. If you are going to use both they both have to be switched. The reciver input does not even connect to the board inside it just passes striaght threw to the reciver so if you dont want to plug it in there you do not have to. I hope this will help you. |
RE: I4c Isolator...
Dave,
Ditto what Rob said. I have on in my Tamjets F-16 and it works fine. Two batteries on mine, both switched. |
RE: I4c Isolator...
Thanks guys...i have one or two I4c products i bought a while ago ...only now are they about to be put to use..:) Brg Dave. |
RE: I4c Isolator...
I had one in my F-16, but pulled simply to save weight, space, and simplify the radio system
| All times are GMT -8. The time now is 08:43 AM. |
