RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   elevator servos for Jurrasic (https://www.rcuniverse.com/forum/rc-jets-120/5921172-elevator-servos-jurrasic.html)
rhklenke 05-30-2007 11:20 AM
Hey guys,
I'm having a Jurrasic Jet ( http://www.altecare.com/jurassic.html ) built for me and I need to decide on what servos to use for the elevators. The problem is, the elevator servo pockets (in the stabs) are only 0.55" thick.
Probably the two best alternatives are:
Futaba S3150 Digital
Torque: 51.4 oz-in @ 4.8V
Dimensions: 1.1x0.5x0.8 in (28x13x19.7mm)
http://www2.towerhobbies.com/cgi-bin...&I=LXFLA0&P=SM
JR DS368BB Digital
Torque: 53 oz/in @ 4.8V
Dimensions (WxLxH): .50 x 1.12 x 1.21
http://www.horizonhobby.com/Products...odID=JRPS368BB
Also, there's the JR thin wing digital:
JR DS168 Digital Thin Wing
Torque: 47oz @ 4.8V ; 53oz @ 6.0V
Dimensions (WxLxH): 0.34 x 1.33 x 1.18 in
http://www.horizonhobby.com/Products...ProdID=JRPS168
Any thoughts on which is best or if these have enough torgue for the job? Any other alternatives I should consider?
Thanks!
Bob
Adil Nasim 05-30-2007 01:31 PM
RE: elevator servos for Jurrasic
Hi Bob,
You should also look at the Volz servos. They have similar size one that is really tough.
Hope this helps.
Adil
rhklenke 05-30-2007 02:19 PM
Adil,
Thanks for the suggestion. I used one of those on the AD F-16 I built for Scott Strimple. I had to track one down from Tad at Goldenwest and it was the last one he had. Do you know of a source for those here in the states?
I talked to a friend of mine who is a big-time glider guy and he said that they originally were popular but now most have gone back to the JR servos (like the ones above) for their high-torque, low-profile applications...
Bob
smokin-gun 05-30-2007 02:57 PM
call dreamworks- he has raised servo covers/ with hump in them .
example, i was able to put 9411 jr in a bobcat where only 3421 or 3301 would previously fit
Adil Nasim 05-30-2007 04:36 PM
ORIGINAL: rhklenke
Adil,
Bob
Hi Bob,
Unfortunately, the source I knew about is Tad at GWM as well. I'll try to see if I can find out if anyone else carries them. If you do get in a situation, I may have a couple used (like new) that I can send to you (no cost). If you can use them - great.
Regards,
Adil
LN-JET 05-30-2007 05:41 PM
My Jurassic is built from the original Jetmag drawings, and with careful placement I was able to fit Hitec 5245's. They are .67"thick.
They are mounted to .040" aluminum covers, and on one of the upper corners they touch the the outside fiberglassing.
Exept for breaking the gears on one of them in a belly landing, they have held up fine.
A small ventral fin would have saved the servo and elevator horns.
Lars
Peter A 05-31-2007 09:14 PM
ORIGINAL: rhklenke
I'm having a Jurrasic Jet built for me and I need to decide on what servos to use for the elevators. Bob
Hello Bob
Here is the link for the servos you need:
http://www.soaringusa.com/products/p...ategory_id=269
Address:
SoaringUSA.com
809 N. Glendora Ave
Covina, CA 91724
Phone: (626) 967-6660
Hours: 9:00am - 4:00pm, PST Monday - Friday
Email: [email protected]
regards
Peter
rhklenke 05-31-2007 09:31 PM
Peter,
Thanks very much for the information - great service as usual! I have a pair of the Voltz servos on order. I'll send you some pictures when we get it ready - hopefully by the end of June. Then it should be flying autonomously with our flight control system by the end of the summer...
Bob
ps. Adil, thanks very much for the kind offer. If it was just for me, I'd take you up on it, but this is for our NASA work, so I need to go with NIB.
Thanks guys!
