Weatronic update 12 channel and sequenser
guys seen the latest firmware?
cool sequenser build in.. good now i can take out my old one and save another 40 grams on my Frightning.. |
RE: Weatronic update 12 channel and sequenser
i buyed a 10 channel..
now i have a 12 with sequencer!! great!!! :D |
I just wish they worked with my "Scare-Tronics", I just can't live without my Stylus.
All,
Can you upgrade the 8-12, or its only for the 10-20 versions? If yes, do you end up with 8 PCM and 12 PPM? Thanks |
Anyone?
I have 8-12 that I upgraded and you get 12 channels.
All,
Can you upgrade the 8-12, or its only for the 10-20 versions? If yes, do you end up with 8 PCM and 12 PPM? Thanks You will end up with 10 PCM and 12 PPM. Gerhard |
ORIGINAL: gerhardp You will end up with 10 PCM and 12 PPM. Gerhard I guess that means the discontinued the 8-12 model, right? Otherwise people will buy the 8-12 at lower price and then upgrade for free! |
Hello Edgar,
you can upgrade a DR 8-12 to a DR 12-12 not to a DR 12-20 |
| All times are GMT -8. The time now is 08:09 AM. |
