Insulating blanket mat'l source
Does anyone have a good source for the ceramic blanket material, similar to what BVM sells?
I need it a bit thicker and with a foil backing to provide temperature protection between the tail pipe and white foam in the fuse. of my large turbine U-2. I am using a cooling shroud on the tailpipe but it's 46" long also. I will need about 9ft^ of it. Jack |
I got mine from Aircraft Spruce & Specialty Co. Very reasonable price.
Jack,
Check with Summit Racing. They usually carry several sizes of the ceramic/foil blankets. Here's an example of one they sell. |
info
| All times are GMT -8. The time now is 04:16 PM. |
