Graphic Removal
Any suggestions on removing old pro-mark graphics from a clear coated surface, without sand paper. Rubbing alcohol works, but it takes alot of "RUBBING". Looking for any other ideas.
Thanks, Jed |
RE: Graphic Removal
I would try 'Varsol", a paint remover and then MEK if you can get it. I found it removes just about anything I didn't want removed. Powerful suff!
RE: Graphic Removal
3M makes a product called, Cleaner Adhesive remover. Safe for clear coat
Part #8984, quart can or #8987 spray can. Get it at a store that sells automotive refinishing products. |
RE: Graphic Removal
Thanks for the replies gentlemen, I had some MEK sitting around, worked great! The decal melted, the plane melted, and my liver melted[:'(] . It didn't mess with the clear coat, and at least I only had one stars and bars to remove.
Thanks, Jed |
| All times are GMT -8. The time now is 02:35 PM. |
