Lightning main struts - improved design
1 Attachment(s)
This may be old news, but the Lightning main struts have been improved.
The original had only one bolt with brass bushing. If the bolt shears, the wheel will rotate & bring the jet to an abrubt hook turn with possible damage. I suffered this on take off roll & it was a little dramatic. I fly off semi-rough grass, so I'm sure that added to the stress on the bolt. I suggest you check yours periodically. The new design has 2 large diameter brass bolts. Hopefully these will hold up better. Just thought other Lightning flyers would like to know of the update. ...Scott |
RE: Lightning main struts - improved design
Thank you for the update.
Hi.
Great news? I've had no problems so far with mine, but better safe than sorry:D Do you know if the update can be ordered from C-ARF and if so what has to be changed? Just the lower strut or also the upper strut with longer slide for the two pins? Thanks for sharing! |
I just called my C-Arf rep Ray Labonte's shop looking for the bolt/brass pieces. That's when I was told about the improved strut. I had 2 new struts in my hands within 3 days. I'm assuming all new gear kits will have the latest version.
I flew today for the first time on the new struts. I may just be my imagination, but it seems like the springs are stiffer. The slide length is the same as the older strut. It would make sense to use a stiffer spring because the added pin reduces the slide travel. My old struts were pretty worn, but they feel softer that the new ones. If they hold up after a few months on grass I'll be happy. |
1 Attachment(s)
I've modified my wings to eliminate the gear doors and added trailing links.....
Ron, that is the best solution I have seen to date. It really is the best solution overall. What retract mechanism is that?
It's still a secret...until after testing....I promised..............but they will be readily available...once the correct spring is found.....
A retract mech that uses a spring? Not sure I buy that. PM me, we may have a common friend.
Further reports?
Hey Sean - Ron's trying to sell his Lightning (check the classifieds) I'm going to talk to him at Spiderman in Winamac next week.
As far as the new Behotec struts, I had about 27 flights on them and they were doing ok, but seemed a little stiff. I found the brass slider in the C-50 retract tending to bend more over time than with the original "softer" struts & flying off grass doesn't help. I'm tempted on getting a set of Jet-1A knee struts & try different springs from McMaster-Carr. They have small cot & ultra-precision springs that may work. Sandor/Digitech is supposed to be working on springs for the Lightning, but he's got a lot of other projects going on so its taking a while. |
| All times are GMT -8. The time now is 01:32 AM. |
