RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Small panel mount voltmeter (https://www.rcuniverse.com/forum/rc-jets-120/619615-small-panel-mount-voltmeter.html)
Tom Antlfinger 03-12-2003 08:27 PM
Anyone have a source for the small LCD voltmeters, about 1" x 2". I also have seen them in a 1"-1.5" round configuration.
I need a couple of them for one of my new planes and for my new power box panel.
Thanks---Tom
Rojeck 03-12-2003 08:53 PM
Voltmeter
Tom have you looked at the I4C Products voltmeter, they are about the size your are talking about. I will look for their web address later and post it for you.
Sung
Gordon Mc 03-12-2003 09:15 PM
Here ya go:
http://www.i4cproducts.com/c-volt.htm
Gordon
JimTrainor 03-12-2003 09:20 PM
Jameco have'em for $12.95 :
All of them:
http://www.jameco.com/cgi-bin/ncomme...ch=panel+meter
One of them:
http://www.jameco.com/cgi-bin/ncomme...nbr=501&ctgys=
Tom Antlfinger 03-12-2003 09:59 PM
Voltmeter
Thanks---just what I needed.
Tom
kelly vallee 03-12-2003 10:57 PM
This are very nice and good, but watch out they do not have a built-in load tester. Kelly
Gordon Mc 03-13-2003 04:08 AM
Since they stay in the aircraft all the time, and are active the whole time the radio is turned on, your whole radio system is the built-in load tester.
Regs,
Gordon
aparchment 03-13-2003 04:04 PM
Jameco Description
LOL! Check out the Jameco PDF file for the digital meter:
http://www.jameco.com/Jameco/Products/ProdCT/p037.pdf
"Digital Penal Meter" !!!!!!
Man that's gotta hurt! Is this a new FAA medical requirement? If so I guess they can have my license!
Antony
rhklenke 03-13-2003 07:02 PM
All of them:
One of them:
Note that according to the spec. sheets, the Jameco ones require a separate 9V battery to supply power to the display...
Bob
Gordon Mc 03-13-2003 07:15 PM
Re: Jameco Description
Mine reads 10.7 ;)
I'm just glad that it's a voltmeter. If it had been a pressure gauge, they would probably also have managed to do a typo on PSI.
Gordon
Tom Antlfinger 03-13-2003 07:17 PM
Voltmeter
Yes, I have noticed that the external battery is required on the cheaper Jameco's.
I will probably go with that one for my power box, since I have the voltage available, but will stick with the I4C one for the planes, since I don't want to stick in another battery.
I have one in my current flying Bandit. It just did not have a label on who made it, which is why I posted originally. It looks exactly like the I4C unit. It came in a D/F plane I bought a couple of years ago.
They sure are pricey though.
Thanks again for the help
Tom
JimTrainor 03-13-2003 07:31 PM
http://www.jameco.com/Jameco/Products/ProdDS/108388.pdf
The full spec reads 7-11 V @ 1 mA
A 9V battery will last quite a while at 1mA. If the battery is objectionable, then step down/up the DC supply per requirements.
A 3 kOhm resistor will drop a 12V battery down to 9V if the 1 mA draw is correct.
rhklenke 03-13-2003 09:04 PM
The problem is in an aircraft flight system where the battery voltage is either 4.8V or 6V nominally. The i4cproducts ones designed for aircraft mounting probably have a DC-DC converter in them to supply the power to the display, or they have a lower voltage display which costs more than the Jameco one. Either way, that probably explains the higher cost of the i4cproducts units.
Bob
