eMachineShop.Com?
Has anybody ever used [link=http://www.emachineshop.com/]eMachineShop[/link] and wish to share their experience? Good? Bad? Use of their design CADware?
RE: eMachineShop.Com?
Hi Mike,
I used them, the process worked OK. The software is a bit tricky to use as it is designed around their processes that are unique. I used plasma cutting (IIRC), brake bending and drilling. All stainless steel and the process worked and the parts I got were correct. I think CNC machining of aluminum would be easier but expensive. Let me know how it goes. Regards, |
Matt replied ... Let me know how it goes. |
1 Attachment(s)
ORIGINAL: mr_matt Hi Mike, I used them, the process worked OK. The software is a bit tricky to use as it is designed around their processes that are unique. I used plasma cutting (IIRC), brake bending and drilling. All stainless steel and the process worked and the parts I got were correct. I think CNC machining of aluminum would be easier but expensive. Let me know how it goes. Regards, |
1 Attachment(s)
I can do all your flex plate stuff, right here in my shop without having to drive down the street to my buddies shop. Carbon fiber is really expensive right now, I would suggest G10 Flex plate material and give it a try.
Nice setup Sean. I am trying to get my buddy to hurry up and finish his CNC so I can start cutting some stuff out too
Once you cut out a servo hole, or airline holes or velcro holes for a receiver into a piece of wood with one of these, you will never ever ever want to go back!
Wow Sean ! You have all the toys ! What programs are you using for the whole process ? Design , G code , running the machine ?
Marc |
G Code, and I wouldn't say all the toys, just enough to know there is always more that I want!
Hey Sean , did your response get cut in half or something ?
Marc |
Mike,
Friend of mine used emachineshop to get a prop adapter made for a big electric motor. Service was good, finished product was excellent, price was astronomical. Jerry N |
1 Attachment(s)
HOLY CRAP, Sean!
Dualing CNC mills? Very nice. I have been thinking of making my little Sherline a CNC machine...........Now I'm thinking I should just e-mail you when I need a part:D Here is a pic of some work done by my fly'in buddy, Wayne for the A-7. He is using a set up similar to yours. Tailwinds, John |
And I thought I was "serious" about the hobby 6 years ago when I built and flew a Kangaroo on a Ram 1000! ;)
My how things change when you get REALLY "serious" :) hahahaha I've admired y'alls project from the beginning bud. Stuning as always! |
1 Attachment(s)
Thanks Sean. The folks at Mesa were kind enough to lay Best Finish on me!!
If I get to AUS some time, I'll look you up. John |
bring it to Waco next year at the GSWJR
hopefully Dave Hudson will have the finished product for his F-8 by then. they would look good next to each other |
Sean
I will never inquire again if you used a hatchet on your lattest project Your shop in becoming impresssssive!!! A big change from the last photo's I saw, with the figure of an Isobar in overspray on the concrete!!! Jerry |
1 Attachment(s)
I LOVE MY OVERSPRAY! Adds character!
| All times are GMT -8. The time now is 12:28 PM. |
