RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Powermax Trigger Valve (https://www.rcuniverse.com/forum/rc-jets-120/6297469-powermax-trigger-valve.html)
tothemax 08-28-2007 08:08 AM
Anyone know where to buy one?
Square Nozzle 08-28-2007 08:21 AM
RE: Powermax Trigger Valve
Great Northern Models has a BVM Trigger valve in the fuel accessories section. A little pricey at $39.95 but it looks like quality stuff as is with all BVM products.
Square Nozzle 08-28-2007 08:27 AM
ORIGINAL: John Palica
OOOPS- On closer examination, the Trigger Valve is no longer available. It seems that I saw one elsewhere. I'll keep me eyes open for another.
Synthetic 08-28-2007 09:04 AM
If you find out who has some will you pm me as I am in need of one also.
Don
jockjets 08-28-2007 10:13 AM
Hi there
Daryll Usher made the Powermax Trigger valves. http://www.acsip.com/~dgu
He states on his website that he has stopped manufacturing them, but he may have some stock left.
Worth a try.
Best of luck
Ian
Synthetic 08-28-2007 10:40 AM
Thanks Ian...
Synthetic 08-28-2007 10:46 AM
I went to that site but in big letters it says, "No more Trigger Valves"! I guess he must have been getting several requests.
For those of you who use Powermax and don't use the Trigger Valve, what are you using to fill your propane tanks?
Don
drdoom 08-28-2007 11:08 AM
My JetCat came with a Small piece of tube that you just incert into the top of the can. You have to PULL it back out when you are ready to disconnect.
It works, But the trigger was cool.
3DHELINUT 08-28-2007 11:44 AM
Here are a few places you can try, you will have to modify the valve by adding a barbed nipple to the end. What you are looking for are Photographic air duster trigger valves that are available all over the internet and camera shops.
[link=http://www.pecaproducts.com/trigger_valves.htm]http://www.pecaproducts.com/trigger_valves.htm[/link]
[link=http://www.cleanoptics.com/shopdisplayproducts.asp?page=2]http://www.cleanoptics.com/shopdisplayproducts.asp?page=2[/link]
[link=http://www.pfile.com/cgi/cart.cgi?db=dusters_cleaning.db&search=Chrome+Trig ger+Valve+-+For+Dust-Pro+8+oz.&method=phrase]http://www.pfile.com/cgi/cart.cgi?db=dusters_cleaning.db&search=Chrome+Trig ger+Valve+-+For+Dust-Pro+8+oz.&method=phrase[/link]
Alan
Synthetic 08-28-2007 11:57 AM
Thanks Alan, I will check them out!
Don
bevar 08-28-2007 12:17 PM
Todd at Dreamworks sells this...
http://dreamworksrc.com/catalog/prod...roducts_id=774
Maybe that will do?
Beave
3DHELINUT 08-28-2007 12:26 PM
That valve will not work with a powermax bottle, that valve is for propane bottles.
Alan
Square Nozzle 08-28-2007 12:35 PM
ORIGINAL: drdoom
"Pull" is the operative word here. I also fill by onboard tank for my P70 in the same manner. You really do have to pull to get the insert fitting out. I thought I had a problem but I guess it's common.
jonkoppisch 08-28-2007 12:38 PM
You may have to shave a little more off of the plastic nipple to get it to pull out easier. Mine wasn't a problem...
maddogg 08-28-2007 12:47 PM
Try Carlos at RTI. Also, be careful with the trigger. It works when you pull it and if it gets pushed forward. Don't ask how I know.
Maddogg
Synthetic 08-28-2007 01:25 PM
[Don't ask how I know.]
Hheheheehheh....
Square Nozzle 08-28-2007 01:59 PM
I did some research in the archives and read that Dreamworks had found a valve that they were going to start marketing when BVM stopped supplying. It was a rendition of a valve that is used by electronics repair people to blow dust out of the funny little parts on P/C boards etc. What ever happened to that source?
lov2flyrc 08-28-2007 02:35 PM
Here is the deal guys....
The trigger valve that Usher used to supply most of the dealers was discontinued by the manufacturer, OS Series II. I was told they discontinued this valve series because the canned air they worked with was also discontinued. We have ordered just about every other brand trigger valve on the market in an attempt to find a new source for converting them to a powermax valve. The problem is, all of the other valves require far too much modification to make them work on a powermax can. Carlos (RTI) and I converted several valves that I acquired but, spent over an hour of labor on each valve to make them usable. Because of the labor involved, we would have to sell the valve for roughly 50.00 ea to make them profitable. We felt this was too expensive and not marketable at this price. SO.... the question is, are you willing to pay 50.00 for a trigger valve?? If so, I will work on making some up....
BTW, I did find ONE trigger valve in stock. First one to contact me can have it....386-852-4793
Todd
DocYates 08-28-2007 02:48 PM
My local source for Powermax, Dick's, has told me that it is no longer available. I know that can't be true, cause I see all you guys being able to get it. I have been to every sporting goods store within 50 miles and have not found any more. The Colemax propane just doesn't work as well for me. I guess I'm gonna have to make a trip to Huntsville or Nashville to find some.
Tommy
lov2flyrc 08-28-2007 03:21 PM
Tommy,
Can you elaborate on why you say the Coleman propane does not work as well?? From my experience with MANY engine brands, Propane works just as well as propane/butane mix BUT, some adjustments usually need to be made to the ECU for start performance to match. The ONLY reason why Powermax became the brand of choice for some manufacturers is because of the pressure level of propane/butane mix which is a bit lower than straight propane. Years ago, when onboard start tanks where introduced, some modelers experienced propane line ruptures. Typically, these ruptures where in high temp conditions where, when baking in the sun fuse temps can exceed 150 deg. This raises the propane pressure in the tank while also softening the propane tubing.
Today, I find many customers removing onboard tanks and going back to straight propane for startup. The propane is easier to find not to mention cheaper, valve is cheaper and it eliminates carrying propane on board.... Heck, harbor freight sells an adapter so you can fill a coleman bottle directly from you barbecue tank!
Todd
PS...trigger valve is now sold!
Vincent 08-28-2007 04:02 PM
I just 6 cans of powermax here: www.ocscoutshop.org
V..
Synthetic 08-28-2007 04:13 PM
Vincent,
That's a dollar higher per bottle than Bass Pro Shops but you may not have one there.
Don
Gordon Mc 08-28-2007 04:15 PM
$3.49 here: http://www.scoutmansupply.com/Produc...ProductID=1008
Synthetic 08-28-2007 04:19 PM
Now that's a good price. How much is shipping I wonder?
Looks like $6.95 shipping. If you bought 6 cans that works out to about $4.70 a can.
Gordon Mc 08-28-2007 04:26 PM
Still $6.95 even if you buy 24 cans or so ... maybe get together with some of other jet guys in your area and put in a larger order to reduce the cost even more.
