RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   C-ARF Flash - tips ? (https://www.rcuniverse.com/forum/rc-jets-120/6301998-c-arf-flash-tips.html)
i3dm 08-29-2007 08:52 AM
Hello guys,
a friend of mine just bought a Composite ARF Flash - and we would like to get any tips about:
- radio setup
- CG
- anything else ?
thanks !
digitech 08-29-2007 09:26 AM
RE: C-ARF Flash - tips ?
ORIGINAL: i3dm
Hello guys,
- radio setup
- CG
- anything else ?
thanks !
Spektrum
as recomended but in between the 2 suggested ones.
yes add power
i3dm 08-29-2007 09:48 AM
digitech,
while your reply is extremely helpful, i would like some more specific details.
For power he has a P120 - im sure its enough. he is using a 9C Futaba, i was wondering about control movements and such.
We do not know the recommended CG since we dont have the manual.
Bob_B 08-29-2007 10:08 AM
Maybe the manual is on the CARF website for downloading.
flash2 08-29-2007 10:12 AM
I HAVE THE FLASH MANUAL IN PDF FORMAT IF YOU CAN GET ME YOUR E-MAIL !
flash2 08-29-2007 10:13 AM
http://www.composite-arf.com.hk/ar/Product?675000
digitech 08-29-2007 10:14 AM
ORIGINAL: i3dm
digitech,
manual http://www.composite-arf.com.hk/arf/....manual.v1.pdf
pics http://www.composite-arf.com.hk/arf/...osheets.v1.pdf
i3dm 08-29-2007 10:14 AM
Please email me at: [email protected]
thanks !
flash2 08-29-2007 10:19 AM
ON THE WAY!
I have a Titan in one of these! Vertical is awesome !
HAMMERDOWN 08-29-2007 03:41 PM
120 is good Titan is better if you want vertical. The airframe is very cg sensitive. 1/4" behind the recommended aft cg and you are in for a ride when landing: ask me how I know.
i3dm 08-29-2007 04:09 PM
Is the manual accurate with control movements in normal, take off and landing modes ?
HAMMERDOWN 08-29-2007 10:27 PM
I used the recommended throws. The ailerons could be tamed a bit but I like them at the factory specs. About 3 revs per second at 190 is very cool but it will also slow roll like a pattern ship if you tell it to.
AFTERBURNER1 08-29-2007 11:28 PM
OH YES IT WILL!!!!!:eek:
causeitflies 08-29-2007 11:37 PM
[:@]Wish I could find time to work on mine...
Ragz 08-30-2007 06:51 AM
would this plane fly at all with a p80?
Amir Assal 08-30-2007 04:56 PM
I have p-120.
quist 08-30-2007 05:21 PM
ORIGINAL: Ragz
Yes, there are people flying it with the P 70.
teamkaos 08-30-2007 05:32 PM
Hi i3dm
I've been flying mine with a P80 and it's more than adequate if you fly from a sealed strip. If you fly off grass you will probably need the P120. I started with the control throws at about 50% of what the manual indicated as they looked too extreme to start with. The flaps are questionable, generally if there's a bit of wind I dont use then for take off or landing. Only in dead still conditions will I use the landing flap and then it's about 50% of the recommended setting.
All up, I love this model, it's my first turbine and I've found it very easy to fly and land. The only drawback is the shear pin arrangement in the main legs but the Jet 1A trailing leg arrangement is well worth looking at. I'm going to retrofit these to mine when they arrive.
Have fun.
Rod
