RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Falcon 60 - Enforcer clone? (https://www.rcuniverse.com/forum/rc-jets-120/6515949-falcon-60-enforcer-clone.html)
erazz 10-20-2007 03:08 PM
1 Attachment(s)
Came across this plane somewhere on the net.
Specs are:
Span: 48"
Length: 46"
Area: 1056 "^2
Weight: 6 lb
Engines: 0.60 to 0.75
Seems pretty close to the Enforcer. If so it would probably be an easy conversion to a 12-14lb turbine. (need a home for my WREN!)
Has anybody seen this airplane? Heard anything?
NM_Mark 10-21-2007 02:24 AM
RE: Falcon 60 - Enforcer clone?
Check out Nitro Planes - they have a plane called the Kangaroo, that looks like an Enforcer clone - with retracts.
Mark
erazz 10-21-2007 07:36 AM
1 Attachment(s)
ORIGINAL: NM_Mark
Mark
I thought so too, at first. But when you look at the specs you see that this is larger.
Meanwhile someone posted it on [link=http://cgi.ebay.com/THE-FALCON-60-DELTA-WING-PUSHER-JET-GIANT-SCALE_W0QQitemZ120174188368QQihZ002QQcategoryZ1916 4QQssPageNameZWDVWQQrdZ1QQcmdZViewItem]EBAY[/link]...
I just might try to do this :D
joeflyer 10-21-2007 09:04 AM
It looks a lot more like the Force One, a bit larger though. The Force One was also designed by Laddie Mikulasko and in available from Balsa USA.
Joe
erazz 10-21-2007 09:34 AM
I know it looks like a Force One but it's the same SIZE as the Enforcer.
