RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Battery Setup For 2.4Ghz (https://www.rcuniverse.com/forum/rc-jets-120/6763558-battery-setup-2-4ghz.html)
MaJ. Woody 12-16-2007 07:29 AM
Hi Guys.
I have been reading about all the power related issues when going to 2.4Ghz. I understand that the solution is to ensure you have the proper setup. Here is what I use in my jets currently:
Two 6V 1950 Mah Nimh packs each rated to deliver 40 amps (packs from No BS Batteries)
Two Heavy Duty switches
Each switch is plugged into a different port in the Receiver
This setup should give me nearly 4000 Mah capacity and 80 amps of current.
I have over 150 jet flights with this setup and never had a problem. Will this setup be OK with 2.4 Ghz?
Dom
rcguy! 12-16-2007 07:51 AM
RE: Battery Setup For 2.4Ghz
ORIGINAL: MaJ. Woody
Hi Guys.
Dom
Dom,
This setup pretty well matches the setup I have in my KingCat with TitanSE power. I use 2 qty 5 cell 2000 Mah Nimh 7mH batteries (from noBS) each connected to the AR9000 RX with its own switch harness. No regulators, diodes, etc. 80+ flights and all is well.
DX7 TX guides her well too!
Dave
MaJ. Woody 12-16-2007 08:01 AM
Thanks Dave!!
Dom
rcguy! 12-16-2007 08:54 AM
You're Welcome!
Nice build on the Panther!
Dave
MaJ. Woody 12-16-2007 09:03 AM
Thanks Dave. I'm having fun:D
Dom
jayman618 12-16-2007 09:38 AM
Dave:
I have the R 921 receiver would that be the same as the AR 9000 in reguards to the battery voltage issue?
Thank you
Jay
rcjet lynch 12-16-2007 09:50 AM
Yes it will be the same. The only difference is on the 921 it already has two labeled battery ports.
jayman618 12-16-2007 10:04 AM
Thanks Rob
rcguy! 12-16-2007 10:19 AM
ORIGINAL: jayman618
Dave:
Thank you
Jay
PM reply sent.
Dave
rcguy! 12-16-2007 10:20 AM
ORIGINAL: rcjet lynch
Place of manufacture maybe? I believe the servo ports are inverted from the AR9000 ie; negative lead "down"
Getting a bit off topic?
Dave
chipperg 12-16-2007 11:40 AM
I run a 4300 LI on the Wren 54 ss and a 2900 LI on the rec. These are 7.2 volt packs regulated down to 5.6 volts. Is this OK?
Dave Presta 12-16-2007 12:25 PM
Dom, pretty much the same setup that I have been using with my AR9000 except that I use twin 1800 ni-cads. On my hornet I was using 300mah per flight, and my T-33 is using even less.
Enjoy,
Dave
MaJ. Woody 12-16-2007 12:32 PM
Thanks Dave.
I thought I would be OK but wanted to be sure.
Dom
