up2 / up4 question????
were can i get threaded plugs for the up2 /up3 valves. i would like to cap off the unused nipples. or what size thread are the nipples and i will make my own..
thank you Arden |
RE: up2 / up4 question????
They are standard metric threads. Just locktite short metric screws in place then leak test. I have done this a few times. If you remove the nipples you will find that is how they are installed no o-rings or gaskets.
Jerry |
they are a metric 5mm thread hope this helps regards jonathan
The threaded brass air fittings on the Ultra Precision Valves are 3mm x .5 pitch
They are not 5mm like stated above. You can use a short 3mm cap screw or set screw to plug them off if you wish. Darrell |
thank you all , i will get them today i was hoping that it would be that easy..........
Arden |
the corect size is 3.5 mm i have searched the net to find the proper blanking screw . i called percission valve this am and they will ship tomorrow.
Arden |
| All times are GMT -8. The time now is 09:58 PM. |
