FOX COMPOSITES SABRE F86 for Wren 44 build thread
1 Attachment(s)
Next Project!
Decided to get my self a Fox Composites Sabre, the Hawk is so good. Kit arrived, really well packed, professionally done, and of course full fuselage and wing bags included! Great value.;) When you open the box the quality just leaps out….live hinges included, flaps all retract bays and mount…etc..etc. The quality of the moulding is superb. A really nice feature is the two wing tanks beautifully made and just slide into the wings (see pics). This keeps the fuselage clear. I shall run a build thread as normal and update stage by stage, I will not be able to start for a couple of weeks due to work load, but I am really looking forward to doing this one.:D Paul Pic 1: box well packed. Pic 2: contents, note the wing bags Pic 3: more of the same Pic 4: Wing tank, nice fit in the wing |
RE: FOX COMPOSITES SABRE F86 for Wren 44 build thread
1 Attachment(s)
Pic 5: Quality wing moulding
Pic 6: Live hinging Pic 7: Bottom view of wing, servo boxes cut. |
1 Attachment(s)
Pic 8: UC mounts ready for action.
Pic 9: Sharp quality moulding on the fuselage. Pic 10: More of the same. Pic 11: Top view of Fuselage. More to follow as soon as i can get started. Paul |
Paul,
Looks good but any reason why molded all yellow?? Kinda forces you to paint the whole thing? At least if it were silver you could whack a few decals or stripes of paint and cover off 90% of schemes out there?!?!? Rgds, Mark |
Paul
I'll add this model to list for Bickley then shall I. What else you bringing?? Gregg |
Yellow is an option, silver and white also.
I wanted yellow to do a sport colour scheme but I understand that there was a yellow F86 full size! Yes I shall bring this to Bickley, also the Hawk, Jetmach 44 and L39. Roll on summer:D |
Fox Comp have just put the instructions for the Sabre on the web site...nice [8D]
[link=http://fox-composites.com/instructions.html]Here[/link] Paul |
Paul,
Keep it coming. We are interested and there are no questions because you cover it all. A good read. Trevor Skedge |
Thanks Trev ;)
1 Attachment(s)
here is the scale version yellow scheme.
http://www.clubhyper.com/reference/sabre5jh_1.htm gordon dickens' pilot/builder ... also another yellow scheme |
Hey Pat how you doing?
Thanks for the Pics, maybe i will do it scale after all.....[8D]:eek: Paul |
doing well paul considering. just had a baby last week and am recovering from an eye incident so my boomer has been sitting collecting dust. really considering one of these little f-86's. do you know if the viggen is under consideration by Jim?
Pat
Sorry to hear that, please get well soon. I am not aware of any work on the Viggen. But the Hawk and the Sabre are fantastic ;)[8D] Paul |
Hi all.
Well, finally got going on the Sabre. Will be 'upping' some build info very soon [8D] Paul |
paul, how much is this kit? Looks very nice.
1 Attachment(s)
I think the kit is around £500.00, give Motors and Rotors a call.
OK First up. I will not be doing such a detailed build on this one, mainly because the instruction (link provided above) are so good. But there are parts that i will do my own way and these may be an option for others. The first thing to work on is the stabilisers (tailplane to us Brits!) The instructions show 2 JR flat servos and uses 1 channel for each servo. The RX I am using is only 8 channel so I will Y the two together. This means that both servos must be installed identically and also the same way round. Pic 1 Shows the mount I have made to hold the servo. Pic 2 Servo test fitted in mount. Pic 3 Test fitting servo. Paul |
1 Attachment(s)
The instructions were followed with regard to the control arm, this involved a 3 mm tap.
Pic 4, 5, 6 show the servos fitted and linkages made. On 6 you can see that the servos sit differently in both side as they are the same way round. |
1 Attachment(s)
The covers hinged back and done!
I have started on the rudder servo install. Pics t'mora. [8D] Paul |
1 Attachment(s)
Rudder servo install is a piece of cake.
The mount is already in the fin, so it is just screw in, cut a slot and fit the control horn (3mm tap again). Pic 1 Shows servo in place. Pic 2 Fin with slot and loose fit location rod. Pic 3 Loose lit fin to Tailplane assembly. [8D] |
1 Attachment(s)
Pic 1: Another view of tailplane and fin assy.
Pic 2: Fin and tailplane assy loose fit on fus. Pic 3: Another view, same. Well, all servos in at the back end! Now for the wings! [X(] Paul |
Hi Paul
I had heard that Jim was no longer making his models. Do you know what the current situation is? John |
Looks good Paul.
Are there any websites with prices ? All the shops on the FOX homepage links to, dont seem to have the products and prices on their sites. |
ORIGINAL: Jgwright Hi Paul I had heard that Jim was no longer making his models. Do you know what the current situation is? John No this is not true, there was a problem but all looks OK now. Paul |
ORIGINAL: SJN Looks good Paul. Are there any websites with prices ? All the shops on the FOX homepage links to, dont seem to have the products and prices on their sites. No sorry i do not know, the web site is a little out of date! Dave has them in at Motors and Rotors as far as i know. Yes, it is a nice quality kit. Should go together very well,and is perfect for a Wren 44. Paul |
Paul
Thanks for the info. I picked it up from RCGroups and they must have had out of date info. His models are really good EDF propositions and it would have been a real loss if they were not available. John |
