JetJoe 1400 Airframes
I'm curious to see how many airframes are compatible with this size engine. IF YOU OWN a JJ1400, please post your info and pics here! Should be cool to see what everyone is doing.
NO FLAMING, Please. Thanks guys, Chris |
RE: JetJoe 1400 Airframes
I have 2 JJ1400, one on a Falcon120, and one on a RedArrows Hawk, havn't flown the Hawk yet but the Falcon flies great. Cermark f-16 would also be a good match
Matty |
ORIGINAL: MattyC-130 I have 2 JJ1400, one on a Falcon120, and one on a RedArrows Hawk, havn't flown the Hawk yet but the Falcon flies great. Cermark f-16 would also be a good match Matty Hi Matty, Can you post pics of your install in the Hawk and Falcon? |
Here is a pic my Friend, Larry Lewis, and his JJ1400 powered Falcon 120. I have a JJ1400 and Falcon 120 on the way, so no pics of mine yet.
1 Attachment(s)
I converted a Nitromodels Keecat 65 to take a JJ-1400. It's a really good combination and flies really well.
Cheers Ross |
ORIGINAL: Shadow9926 I converted a Nitromodels Keecat 65 to take a JJ-1400. It's a really good combination and flies really well. Cheers Ross That's cool. I thought about this one. Do you have any video? How did you mount the turbine? |
Model Engines in Oz (also distribute JLT - Jet Joe engines) have released a Grumman Panther designed for DF or that size turbines.
http://www.modelengines.com.au/Whats_New.html#whatsnew1 Whoops, sorry, I don't own a Jet Joe - ignore my post! - John. |
1 Attachment(s)
ORIGINAL: ScaleFreak I'm curious to see how many airframes are compatible with this size engine. |
Just found this one:
Yellow Aircraft "Stingray"...kinda looks like a mini Hot Spot- |
And this one too...also from Yellow Aircraft:
Sorry, no video. I mounted the turbine on home made aluminium mounts, made out of bent 3mm sheet. They look similar to the supplied plastic mount, but are longer. I had to drill a 33mm hole in the firewall for the starter motor to just peak inside the fuselage to get the C of G right.
A few JJ1400 engines hee flying on Falcon 120s with great results !
Indeed!
Another one suitable for the JJ1400. Looks like it's basically a Baby boomerang copy. They call it the "Formost 150". |
Matty,
Did you ever get to install the JJ1400 in that Hawk ?? |
ORIGINAL: i3dm Matty, Did you ever get to install the JJ1400 in that Hawk ?? Matty |
