RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Anagram HELP (https://www.rcuniverse.com/forum/rc-jets-120/7063561-anagram-help.html)
cmjets 02-12-2008 11:16 AM
Anagram HELP
1 Attachment(s)
Hi Friends::)
I look for the anagram of the Grim Reapers in the F-14D ( VF-101 ).
I put you a photo. I need a source of quality for get the correct shape of the anagram, for them cut it in vinil.
Many thanks in advance.
Regards from Spain.
__________________________________________________ __________
http://cmjets.blogspot.com/
cmjets 02-12-2008 02:49 PM
RE: Anagram HELP
Hey !!!!!!!!!!!!!!!!!!!!!! :D
Does nobody know anything ???????????????????
I need the skeleton draw.
Thanks.;)
ianober 02-12-2008 02:53 PM
RE: Anagram HELP
Do you have a larger picture? If I had one large enough to trace I could cut a stencil.
weasel33 02-12-2008 04:30 PM
RE: Anagram HELP
1 Attachment(s)
You can get these from Twobobs http://www.twobobs.net/
do a search for grim reapers
scan and blow up to whatever size you want
regards
Brian
cmjets 02-12-2008 05:35 PM
RE: Anagram HELP
Hi again::)
I will try draw it with the Corel Photo-plaint, but when I increase, the image distorts.
If you get another source more big, I will grateful to you.
Regards.;)
dbarrym 02-13-2008 02:05 PM
RE: Anagram HELP
1 Attachment(s)
ORIGINAL: cmjets
Hi again::)
You can use Corel to fix any parallax errors that come from an off-angle picture source...you can also use Corel to trace the rough outlines created by blowing up a small image, creating a smooth line that you can then make your masks (or a decal) from. It helps to have the image in Corel greatly expanded (like 10 to 20X) while you work on it. Here is an example of a graphic that I made from a rough source photo, and the trimmed and traced rough image that has been parallax corrected. Unfortunately the final print image is a Corel file format that can't be posted here.
You could also BUY the decal sheet from Twobobs, scan it, and scale up/clean up with Corel. This is the best method if a decal sheet is available for the scheme you want.
Barry
