RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   CG Machine (https://www.rcuniverse.com/forum/rc-jets-120/7125233-cg-machine.html)
Synthetic 02-23-2008 06:28 PM
CG Machine
Every time I ask you guys for some ideas you never cease to amaze me with your ideas and inventions.
Tell me the different types of equipment you use to balance your jets to adjust the center of gravity.
Pictures would be great too.
Seems like when I think I have a way worked out to do something....someone here has a better idea.
Let's see some "CG MACHINES"!
Don
bcovish 02-23-2008 06:50 PM
RE: CG Machine
1 Attachment(s)
This is what I use for KingCats, Boomerangs, etc. It's handy if you don't have any help with the bigger aircraft. And it's adjustable, just unscrew one of the dowel rods and place where needed. It's crude but it works
Edgar Perez 02-23-2008 06:51 PM
RE: CG Machine
An inverted chair, with some protection on the leg for the airplane
highhorse 02-23-2008 07:54 PM
RE: CG Machine
ORIGINAL: Edgar Perez
Oh my god, of course ![X(]
Doh! That's so stupid-simple that it's brilliant ! The best ideas are always ridiculously simple and make me ask why I didn't think of that.:eek:
causeitflies 02-23-2008 08:56 PM
RE: CG Machine
What's so simple about it? I couldn't get it to work.[:o]
Synthetic 02-23-2008 09:11 PM
RE: CG Machine
Nice chair Mark!!!
Don
Ron S 02-23-2008 10:53 PM
RE: CG Machine
1 Attachment(s)
I've decided I prefer to hang them. In the pic here, I just make a plywood plate (2, identical), that slips around the wingtubes, and fits between the model and wing. Your model configuration may or may not allow for that. The nice thing about the plates, is you can then drill locations that correspond to various %mac, so you know exactly where your CG is (25% mac, or whatever.) Or if its a kit, just drill the plates where it needs to balance, and maybe 1/4" fwd and aft of that, whatever... You can then retract your gear, and check that CG. Then you can write it all down and store it with the plywood plates, till the big ol' repair job comes, and you hafta do it all over again!... :)
747drvr 02-24-2008 08:25 AM
RE: CG Machine
1 Attachment(s)
Same here but in this case I'm hanging the airplane from screws that are located at the CG point on the wing root . Pretty slick way . A 32 lb airplane is a little too heavy to lift up with your fingertips !
Synthetic 02-24-2008 08:59 AM
RE: CG Machine
Thanks guys.
Great ideas.
Keep 'em coming. I bet many pilots will be helped by these ideas.
Don
yeahbaby 02-24-2008 12:16 PM
RE: CG Machine
as simple as it seems, I purchased one of the Great Planes CG Machines a few years ago.
It handled the weight of my Yellow Twin Hornet with no problem.
if the base is too narrow for your project, all you have to do is acquire a pair of larger rods to widen the support structure.
Warwick Laken 02-24-2008 12:28 PM
RE: CG Machine
1 Attachment(s)
Heres my offering, uprights 30inches on sliding base to accomodate all jets balanced so far.
Synthetic 02-24-2008 12:55 PM
RE: CG Machine
yeahbaby , what is the weight of your twin Hornet? I have that same Great Planes CG machine but I have never used it for a big or heavy plane.
Don
yeahbaby 02-24-2008 01:17 PM
RE: CG Machine
Amigo
it weighed aprox 32lbs.
Synthetic 02-24-2008 01:25 PM
RE: CG Machine
yeahbaby ,
Wow, I would not have thought it would support that much weight. Thanks...
yeahbaby 02-24-2008 01:29 PM
RE: CG Machine
no sweat amigo.
unless you widen the support base, some of the larger models can be challenging to balance. I ended up inverting the big bird, so you can imagine this quote from my son.... "Dad is this a good idea?" when we balanced the beast, the fins cleared the ground by mere inches
Silence.....I Keel You:D
Synthetic 02-24-2008 01:40 PM
RE: CG Machine
You gotta love Achmed! :D
yeahbaby 02-24-2008 01:45 PM
RE: CG Machine
Stop Touching Meeeeeeeeeeeeeeeeeeeeeeeeeeeee
pilott28 02-24-2008 02:21 PM
RE: CG Machine
I bought 3 digital scales for 30 bucks apiece and find CG the way they do on full scale aircraft. Visit the Jet Pilots Organization web site for the spreadsheet with all the formulas. Takes three measurements and then three weights ... one on each wheel. Works with any size aircraft with no hanging.
There are several spreadsheets out there for various planes.
www.jetpilots.org pick the members tab and then weight and balance from the sub-menu. I am getting ready to post more spreadsheets this evening.
Thud_Driver 02-24-2008 02:37 PM
RE: CG Machine
1 Attachment(s)
You can do it with one digital scale and to a high degree of accuracy.
Change the below file extention to .doc and open in Word.
Have to make a few measurements. Nicest thing is you can sit on the scale all day and move things around until you have it dead on.
smooth sailing 02-24-2008 02:43 PM
RE: CG Machine
1 Attachment(s)
I prefer the hanging method also except I use a plumb bob to find the c.g.
GSR 02-24-2008 02:46 PM
RE: CG Machine
I have used this one in the past, works fairly well.
http://home.mindspring.com/%7Ethe-pl...%20Machine.htm
Charts 02-24-2008 03:22 PM
RE: CG Machine
I used the Great Planes C of G machine to set up the Flash after I'd seen someone from that thread use it. I wasn't sure it could hold that weight, but it was fine. It can take up to 40lbs!!
Thanks for the pointer to the jetpilots website pilot28, some great info on there!
Chris
Synthetic 02-24-2008 03:48 PM
RE: CG Machine
These are GREAT ideas guys!
Synthetic 02-25-2008 02:31 PM
RE: CG Machine
Anyone else? Anything different from these listed?
Don
1Eye 02-25-2008 10:38 PM
RE: CG Machine
I concur w/Keith (pilott28): The weight/moments method with the spreadsheet is the cat's meow. Why lift, hoist, bang your jet around? Just slap it on the scales, make the measurements (which you only need to take once) and plug in the weight(s) - just like the big boys do it - and VERY accurate too. You'll soon be asking yourself why you hadn't done it this way before!
