Hornet
Does anyone have dimensions on the LEX fences and info on their proper placement on the FA18/A? Appreciate any help.
Dan |
RE: Hornet
1 Attachment(s)
Dan,
Does this help? Jeff |
RE: Hornet
Is that big Hornet twin? Would give me scale....
Dan |
RE: Hornet
yes it is amigo. and I believe Paul Reese from San Diego fabricated those LEX Fences.
RE: Hornet
1 Attachment(s)
Here's what I have accomplished so far. I decided to modify the LEX and show the air intake bypass exit ducts in their closed position. I can't seem to find a picture anywhere that shows them open and it seemed like a easy mod to do. I used my Dremel with a cut off wheel and sawed the protruding duct off, cleaned up the opening a bit and made a backer out of 1/64" ply. The backer was ca'd in with glass cloth epoxied over the back to reinforce it. Then I made another 1/64" thick ply patch that fit into the opening and epoxied that in place. A little sanding, a bit of putty and primed. I think it turned out nice. I've made one of the strakes and taped it in place for the picture. Now I just have to duplicate this on the port side.
Dan |
RE: Hornet
Nice job, Dan!
RE: Hornet
1 Attachment(s)
Looks good.
Buck was correct. |
RE: Hornet
1 Attachment(s)
Just an update on some progress. Both are made and position set on the fuse. They will be painted seperate and installed when final finishing of the jet. I think it really adds to the finished look.
Dan |
RE: Hornet
Like the closed vents Dan. Looks great.
RE: Hornet
Paul,
Can I git a couple more sets of those fences? |
RE: Hornet
1 Attachment(s)
I got to do a little bit of paintwork yesterday on the strakes. I also included some pictures of the paint stencils I'll be using for all the graphics.
Dan |
RE: Hornet
1 Attachment(s)
Couple more pics...
| All times are GMT -8. The time now is 01:12 AM. |
