RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Vectored Thrust Questions (https://www.rcuniverse.com/forum/rc-jets-120/7289149-vectored-thrust-questions.html)
turnnburn 03-26-2008 11:40 PM
I am seriously thinking about putting a Composite Arf Roookie together with a Tam or similar vector thrust nozzle. I was told that a vector nozzle would reduce my turbine engine life considerably ( as much as 60 %). Anbody have any thoughts or experiances along these lines ?
Any other comments about any aspect of vectored thrust aplications would be appreciated. What other kits should I consider ?
causeitflies 03-27-2008 12:20 AM
RE: Vectored Thrust Questions
Did they tell you why the life of the turbine would be affected by the vectored nozzle?
dbarrym 03-27-2008 12:38 AM
From discussions I've had with several Jetcat service guys, it's not that the vectored nozzle is the issue, it's the strain that is placed on the bearings when doing tumbling or high rates of rotation in off-axis manuevers (i.e. tumbling) that the vectored nozzle makes possible. Makes sense as a turbine wheel turning 120K or so is going to act as a pretty good gyroscope, placing a lot of loads on the bearing races and cages/side walls.
Barry
causeitflies 03-27-2008 12:45 AM
Barry,
That makes sense so vectored thrust in a scale plane like a Mig or Raptor doing scale maneuvers should be fine.
turnnburn 03-27-2008 07:54 AM
That seems to make sense. I sometimes do snap rolls with my F-86 and used to with a Bandit. I guess I might want to stop doing this ?? Doing them at or near idle might be a better idea ??
