Digitech New items:
1 Attachment(s)
available from May:
Pro-Lynx Lightning struts: these will replace the original struts , as made by Intairco. you do not need to alter anything ,they are drop in. because of the Unique design these struts can take more then 55LBS!!!. these also fit the New swapped wings fom the ultra Lightning. the wheels and brakes and axle do also fit. the pickup 8mm is also the same. price is 125 Euro,s including local taxes 19% if you are outside EU you pay 19% less. we are taking pre-orders now.. - Pro-lynx landing gears in may we will introduce our all new Landing gear packages the will be a mix of Jet-1A and Ours.. best prices are guaranteed , these are not low quality sets! no casting all cnc made landing gears. from may we will have the following models: Boomerang XL Boomerang Elan Boomerang Intro BVM Electric C-arf FLash C-arf Rookie Airconnect this new item does not only connect all your air connectors , but also make a connection between your aileron and flap servo. on request we can make your own custom airconnect to your size and number of connectors.. |
RE: Digitech New items:
Behotec makes the stock Lightning retracts & struts, Intairco only makes the heavy main wheels & brakes for it.
Good news about the Lightning Pro-Lynx struts, but 2 quick questions... What is the length from the top of the main strut to the axle center? (stock Behotec ~168mm) Are these a straight design like the Jet 1A Elan struts? I will pre-order if they are as long & straight like the stock Behotec ones. Thanks for any info...Scott |
ORIGINAL: sc0tt Behotec makes the stock Lightning retracts & struts, Intairco only makes the heavy main wheels & brakes for it. Good news about the Lightning Pro-Lynx struts, but 2 quick questions... What is the length from the top of the main strut to the axle center? (stock Behotec ~168mm) Are these a straight design like the Jet 1A Elan struts? I will pre-order if they are as long & straight like the stock Behotec ones. Thanks for any info...Scott i know exactly who makes what even intairco uses jet-1a parts for some of his models he sells[)] no but we owned and own and have lighting wings here to test it. our last victim (lightning) got entangled in a wire fence , the wings are fine and where a perfect donor for our try outs:D. we will videotape maybe a stress test:D. length is exactly the same as the behotec struts , it was a real challenge since these are very long oleo,s. there is no Straight design only almost strait design , if it was strait it could happen the oleo could lock with a hard landing. if you pre-order ,dont worry we have a good warranty , if you are not happy send them back.. i made them so they would fit the lighting , it would be a waste of investment to make something that does not work. you can always email us for more info |
| All times are GMT -8. The time now is 11:44 AM. |
