Byron Kfir
Hi everybody
I get a Byron Kfir C2 and i have no plans or documents. is their anyone , who can help me. I need the balance point . |
Byron Kfir
If all else fails, contact John Craig at Iron Bay, http://www.ironbaymodelcompany.com/ They bought all the "Rights" to Byrons Birds and should be able to help you.
Byron Kfir
I flew the Byron KFIR-C2 from 1989 to 2000 and put a lot of flights on that bird. I will be home in a couple of hours and get the measurement for you. I'll even dig up a photo or two for you.
It is a great flying delta. Roy |
Byron Kfir
1 Attachment(s)
The CG is between 8 and 8.5 inches forward of the former that the fan is mounted in.
Roy |
Byron Kfir
1 Attachment(s)
Another photo
Roy |
Byron Kfir
is it possible to measure it from the beginning of the wing, because there is no fan inside but a turbine.
Byron Kfir
which weight does your kfir have?
Byron Kfir
As the fuselage begins to turn into the leading edge of the wing, it is 10.5 to 11 inches back from that point. My KFIR also weighs 13 lbs. Hope that helps.
Roy |
Byron Kfir
1 Attachment(s)
Very Nice! HeresA pic of mine!
Byron Kfir
Hi Jack do fly with fan or turbine
and wich cg do you have?please mechure it from the beginning of the wing.do you heve any documents or plans from it? |
| All times are GMT -8. The time now is 11:38 PM. |
