Correct CG needed BVM electra
Does any know the correct CG from the BVM electra?
i dont need the "theoretic"CG but the more practical CG. most of the time its it more or less a inch difference with many BVM products;). |
RE: Correct CG needed BVM electra
Why not call BVM .
SF |
193 mm/7.6 inches aft of the leading edge.
like i said
i have owned a few bvm models and they all had different cg positions i know where the original is , but as with all their stuff they seem to fly better with a bit aft CG |
The position in the manual (7.6") is a safe starting place.
Simple solution.....For the first few flights, use the CG position stated in the manual. Then move the CG aft about 1/8" or 3/16" at a time as you become familiar with the flight characteristics. Stop when you find the position that suits your ability and flying style. |
Sandor since this is the suggested CG for the electric setup.
I would think it is a very good setup as the electrons still weigh the same at the end of the flight :) |
Hmm! A well thought out answer Electric Bob:)
ORIGINAL: R_Belluomini Sandor since this is the suggested CG for the electric setup. I would think it is a very good setup as the electrons still weigh the same at the end of the flight :) mm true i will go a bit aft... lets see how she goes |
Bob
Sandor is used to me helping him with a good position. Not any more though! Dave |
ORIGINAL: Dave Wilshere Sandor is used to me helping him with a good position. Not any more though! Dave what kindergarten did you went you said again?:eek:. |
| All times are GMT -8. The time now is 07:45 PM. |
