Brake Question
I currently have a plane that is using 7"x2" Sullivan Skylite tires. I would like to equip them with pneumatic brakes. What exactly do I need in order to make this work? Will I need a new hub plus the brakes, or just the hub? Also, the tire is mounted on the aluminum six-bolt hub. Thank you for your time.
RE: Brake Question
I have never heard of any air brakes that can be retro-fitted to these wheels; most RC brakes are designed to be integrated into the wheel, with a custom wheel/hub design. For that size wheel/brake you will probably need to get a custom designed/made set from Sierra, Century Jet, or Glennis.
Good luck in your search- Barry |
RE: Brake Question
contact todd at dreamworks and give him your measurements to see what intarico he can fit you with
RE: Brake Question
Hi,
A friend of mine purchased Kavan electric brakes for large scale planes, try them. [link]http://www.sigmfg.com/IndexText/KAV0263.html[/link] John |
RE: Brake Question
Another guy that you may want to check with, is Tam at http://www.tamjets.com ... I could be wrong, but I think I saw him post something a while ago about him modifying wheels (that were not intended for use wiht brakes) to allow a brake hub to be retrofitted. I think this was for some of the lighter (EDF) kits, so they may be around the size that you are looking for.
RE: Brake Question
Aeroduke. I use the Sullivan Skylite wheels but a little bit smaller in size. 4 1/2's.... My brakes and hubs came from Siera Precision models.
here is the link. http://www.sierraprecision.com/ Great people to work with........ Mark |
RE: Brake Question
Thanks for all of the input guys. I'll check these companies out and let you know what I find. Thanks again.
RE: Brake Question
You can also check out Robart's Unibrake system to see if it will fit your hubs....
| All times are GMT -8. The time now is 04:57 AM. |
