Commercial source for this pump?
1 Attachment(s)
Hello,
I hope this post is within the rules. Sorry in advance if it is not. Does anyone know a commercial source for this pump? Wilcox used to get them but he does not have them any more. I am not trying to make a fuel can or undercut Jersey or anything like that. I need one for a liquid cooled shirt I made (it works awesome BTW). Thanks in advance, |
RE: Commercial source for this pump?
Mc Master Carr has them also.
Neal |
Thanks Sean and Neal!
When I get this fully set up I will post pics, this shirt is a riot and works incredibly well. I have been going through hobby glow pumps like popcorn, I hope this one will hold up better. |
These pumps used to be simple to order since there were few choices - they Greylor went & redid the page with a gazillion options !
Here's my ordering notes from my "rc parts source" doc http://www.smartcart.com/greylor7/cg...item_num=PQ-12 Select options: • PQ-12 • Delrin • HS(0) • Viton |
Matt,
I suppose you are using water (or something water based) as the coolant. If that is the case I would think a windshield washer pump would be a better choice than a fuel pump. I think the seals in a fuel pump usually need the lubricating properties of the fuel to maintain a seal, but windshield washer pumps are designed to work with water based liquids so they don't need lubrication from the substance they are pumping. Probably a lot cheaper too. |
mcmaster.com part # 8220K32
Funny, they no longer recommend this pump for Kerosene, but they do provide a compatibility guide for various types of solvents/liquids. |
ORIGINAL: Kevin_W Matt, I suppose you are using water (or something water based) as the coolant. If that is the case I would think a windshield washer pump would be a better choice than a fuel pump. I think the seals in a fuel pump usually need the lubricating properties of the fuel to maintain a seal, but windshield washer pumps are designed to work with water based liquids so they don't need lubrication from the substance they are pumping. Probably a lot cheaper too. Hey Kevin, Yes that might be better, I wonder if an autoparts store just has them lying around that I could take a look at? |
They do! @ 12.00
| All times are GMT -8. The time now is 05:47 PM. |
