RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   CARF Flash Flap issues (https://www.rcuniverse.com/forum/rc-jets-120/7824788-carf-flash-flap-issues.html)
dubd 08-22-2008 12:22 AM
RE: CARF Flash Flap issues
1 Attachment(s)
ORIGINAL: Misha Javornik
Hi Raf, are you using the full ducting on this jet? are you using the stock pipe ? can you post a picture of your turbine install?
Thank you
Misha
Here is a pic of my turbine install (P-120SE), which is exactly the same as Raf's Titan SE install. We're both using the stock pipe.
BTW - The Flash locked in on landing with 40mm of flaps. No more PIO!
ravill 08-22-2008 10:30 AM
Like Dantley (I think he goes through more avatars than....I don't know! :) ) showed, we don't need no stinkin' ducting!
Raf
