ATJ Turbines
1 Attachment(s)
RE: ATJ Turbines
ATJ Turbines (translated)
ATJ Turbine China-made jet engines officially listed La ~ ~ Taiwan's manufacturing production has been the engine of La paste a few products and plans to fly abroad and share the Friends of sync with the current listing 10.5 KG, and 22 KG thrust engine listed in Figure Excellent material than foreign manufacturers, we have all kinds of CNC machines and turbines balancing machines, electronic testing equipment logistics no problem ~ 10.5KG specifications Full-length: 295 mm Diameter: 111 mm Idle: 33,000 RPM High-speed: 123,000 RPM Exhaust temperature: 560 ° C - 660 ° C Compression ratio: 2.2: 1 Thrust: 10.5kg / max RPM Engine weight: 1.45KG-starter with the ECU, engine - Fuel: Jet A1, JP4, kerosene 5% jet engine oil 22KG engine Specifications Domestic ATJ-220 22KG specifications Full-length: 350 mm Diameter: 131 mm Idle: 30,000 RPM High-speed: 108,000 RPM Exhaust temperature: 680 ° C - 750 ° C Compression ratio: 3: 1 Thrust: 22.5kg / max RPM Engine weight: 2.45KG-starter with the ECU, engine - Fuel: Jet A1, JP4, adding 5 percent for kerosene jet engine oil Fuel Consumption: 640g / pm (Full thrust 22.5 KG) |
RE: ATJ Turbines
Specs & photo's look very good.
Price? Regards, John C |
RE: ATJ Turbines
Where did that text come from ? i dont see it on the main page.
Also, did anyone find an email adress ? |
RE: ATJ Turbines
Have you not had enough chinese engine i3dm ? :D
This one does look nice though... |
RE: ATJ Turbines
RE: ATJ Turbines
Pictures on home page don't have any wires exiting from the starter bullet? Magic maybe?
Darn, My Black and Decker Workmate is being used for another project...... "So many Asian turbines........so few Workmates...." Dave |
RE: ATJ Turbines
The wires might be fed through the starter motor mounting standoffs......that would be nice.
RE: ATJ Turbines
ORIGINAL: SJN The wires might be fed through the starter motor mounting standoffs......that would be nice. Strykaas..any comment on that? Dave |
RE: ATJ Turbines
Wow, that looks an awful lot lit a Merlin MK III.
RE: ATJ Turbines
ORIGINAL: seanreit Wow, that looks an awful lot lit a Merlin MK III. |
RE: ATJ Turbines
ORIGINAL: SJN Have you not had enough chinese engine i3dm ? :D This one does look nice though... While they have some similar appearance to the Merlin, Specs shown are two completely different classes of engines. Specs show they are offering a 22-23 lb thrust class and a 48 lb. Interesting! |
RE: ATJ Turbines
Only 23 lbs of thrust though, wonder where they messed up, their dimensions are almost identicle to an Artes Eagle. Merlin does not come in that size as far as I know.
RE: ATJ Turbines
Hi guys!
The turbines are from Taiwan, not China. The quality is very good... the owner of the company is a guy that has a turbo factory long time ago. They have high tech and they do their own R&D. BR.- |
RE: ATJ Turbines
Monkey King, are you affiliated with them?
RE: ATJ Turbines
jajajaj, nop[:o] I only love jets :D
RE: ATJ Turbines
ORIGINAL: rcguy! ORIGINAL: SJN The wires might be fed through the starter motor mounting standoffs......that would be nice. Strykaas..any comment on that? Dave Dear RCGuy, As you have certainly noticed, the "photos" on the "home page" are not pictures of the AJT workshop (where indeed some things could be staged, like in certain turbine engine companies), but these are simply pictures of turbine engines and accessories. I don't know what you mean by saying that these pictures are staged. Maybe Photoshoped ? Well I would rather believe you're making a fool out of me. PS : Is RCGuy an acronym for Really Con guy ? :D |
RE: ATJ Turbines
I would ask where are the turbine wheels made? By whom? Are they x-rayed? Can we get a certificate?
Some things may look hunky-dory but may be very wrong in essence. It's just so easy to produce good "looking" engines these days. It's not until you fire one up that you see what you got. I'd rather spend my money on a name I can trust. |
RE: ATJ Turbines
ORIGINAL: Strykaas ORIGINAL: rcguy! ORIGINAL: SJN The wires might be fed through the starter motor mounting standoffs......that would be nice. Strykaas..any comment on that? Dave Dear RCGuy, As you have certainly noticed, the "photos" on the "home page" are not pictures of the AJT workshop (where indeed some things could be staged, like in certain turbine engine companies), but these are simply pictures of turbine engines and accessories. I don't know what you mean by saying that these pictures are staged. Maybe Photoshoped ? Well I would rather believe you're making a fool out of me. PS : Is RCGuy an acronym for Really Con guy ? :D ME make a fool out of you? Naw...you do a good job of that yourself..... |
RE: ATJ Turbines
ORIGINAL: rcguy! ORIGINAL: Strykaas ORIGINAL: rcguy! ORIGINAL: SJN The wires might be fed through the starter motor mounting standoffs......that would be nice. Strykaas..any comment on that? Dave Dear RCGuy, As you have certainly noticed, the "photos" on the "home page" are not pictures of the AJT workshop (where indeed some things could be staged, like in certain turbine engine companies), but these are simply pictures of turbine engines and accessories. I don't know what you mean by saying that these pictures are staged. Maybe Photoshoped ? Well I would rather believe you're making a fool out of me. PS : Is RCGuy an acronym for Really Con guy ? :D ME make a fool out of you? Naw...you do a good job of that yourself..... |
RE: ATJ Turbines
RE: ATJ Turbines
Got a reply from Youtube today ;)
Dear sir: Thank you for interested our ATJ Turbines Our Turbine ATJ-120 is 12.3kg thrust jet engine the retail price is USD2,890.- , Our ATJ turbine website is replace new information now , so not more data , next week will finish , web is " www.atj.com.tw " thank you very much and best regards.......ATJ Turbines in Taiwan Taipei city ....Joseph |
RE: ATJ Turbines
SJN, can you PM me their email adress please ?
RE: ATJ Turbines
ORIGINAL: rcguy! ORIGINAL: SJN The wires might be fed through the starter motor mounting standoffs......that would be nice. Strykaas..any comment on that? Dave My name is Joseph ATJ Turbine engine Designer , the starter cable inside motor housing in production version , the wire exiting is our test version ...Thank you ;) |
RE: ATJ Turbines
ORIGINAL: josephfly My name is Joseph ATJ Turbine engine Designer |
