RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Glow plug and plug tool. (https://www.rcuniverse.com/forum/rc-jets-120/8000248-glow-plug-plug-tool.html)
d_wheel 09-28-2008 09:00 PM
Is this the glow plug I need for the Artes Super Bee?
http://www3.towerhobbies.com/cgi-bin...&I=LXBLX2&P=FR
Where can I get a small pick for pulling a loop out of the plug?
Later;
D.W.
swansons 09-28-2008 09:13 PM
RE: Glow plug and plug tool.
D.W.
The plug you want for your Super Bee is the McCoy 9, not the 59. You can get a nice set of the little picks at Lowes in the tool section.
The 9 will work better and last a lot longer than the 59.
John S.
Square Nozzle 09-29-2008 06:54 AM
Why not just bend a small hook in the end of a 'T' pin using a pair of needle nose pliers.? This has always worked fine for me.
d_wheel 09-29-2008 07:36 AM
Thanks for the information!
Later;
D.W.
causeitflies 09-29-2008 10:38 AM
I was going to suggest the bent T pin but I don't even bother to bend it ;)
fw190pilot 09-29-2008 07:35 PM
OS A3 glow plugs work very well and are pretty easy to find. I suggest heating the plug with a ni starter first and let it cool before pulling out the coils. Makes them much less likely to break.
joeflyer 09-30-2008 08:21 AM
A3 plugs have a shorter reach than the McCoys. It appears to be about 1/8" shorter than a McCoy. To make up for the difference you need to pull the element out quite a bit further to reach into the chamber. If you pull the element out far enough the A3's work fine.
Joe
