9303 Programming
I would like comments on how to trim the nose wheel on a X9303 2.4g system. I had all my jets on my 10x and used the aux4 knob to adjust the nose wheel trim. The 9303 does not have a aux knob to use. I have plugged the nose wheel steering into the rudder channel and the rudders into aux 4 and mixed them so I can adjust the steering with rudder trim but I would like be know if there is a better way so I can have trim available on the rudders.
RE: 9303 Programming
That's what I do on one of my jets, then use the sub trim to get everything centered..... the rudder trim can be used to straighten out the steering if something is causing it to pull one way or the other......
The other one, I have a matchbox between the rudder and the nosewheel, so I can run them both on one channel, and still trim them separately..... |
Brian,
Sent you a PM. John S. |
Thanks John
| All times are GMT -8. The time now is 03:24 PM. |
