Titain/Skymaster L-39
Thinking of a Skymaster L-39, I have a JetCat Titain. What do you think of the combo and the airplane ? Thanks.
RE: Titain/Skymaster L-39
Eric is flying one with Super Eagle power and is a rocket. The Titan is same size as the P-120, you may tune down a bit and go fly.
Alex |
No problem. The jet will fly on a P-80. The titian will be plenty of power. You may want to turn it down a bit.
Titan is going to be excessive for that plane. If you don't turn it down then be very conservative with the throttle in level flight. The vertical should be crazy though!!
My concern would be if the flight idle on the Titian would be to much for the L-39, what do you think?
| All times are GMT -8. The time now is 02:21 PM. |
