Frank Turbines
Are they ok to use in US as in certified by AMA???
RE: Frank Turbines
AMA doesn't certify turbines.
RE: Frank Turbines
Andy, I'm not sure if you knew, but the AMA used to Certify turbines, and turbine manufacturers had to go through a process to become certified. Then it was dropped to any engine that is currently in production. I'm not current on all the rules associated with this, but I think even homebuilts now are allowed without certification, but don't quote me on this.
Regardless, if the turbine is a manufactured product from a company that is at least partially in the business of building model turbines, you are AMA compliant. |
RE: Frank Turbines
ORIGINAL: seanreit Andy, I'm not sure if you knew, but the AMA used to Certify turbines, and turbine manufacturers had to go through a process to become certified. Then it was dropped to any engine that is currently in production. I'm not current on all the rules associated with this, but I think even homebuilts now are allowed without certification, but don't quote me on this. Regardless, if the turbine is a manufactured product from a company that is at least partially in the business of building model turbines, you are AMA compliant. |
RE: Frank Turbines
Yup, anyway, there are a lot of guys out there that didn't get this memo so to speak, so the nature of his question I'm sure was related to that.
Good Luck Rhall, Sean |
RE: Frank Turbines
RE: Frank Turbines
ORIGINAL: AndyAndrews ORIGINAL: seanreit Andy, I'm not sure if you knew, but the AMA used to Certify turbines, and turbine manufacturers had to go through a process to become certified. Then it was dropped to any engine that is currently in production. I'm not current on all the rules associated with this, but I think even homebuilts now are allowed without certification, but don't quote me on this. Regardless, if the turbine is a manufactured product from a company that is at least partially in the business of building model turbines, you are AMA compliant. |
RE: Frank Turbines
Mark is correct;)
And they still have guide lines concerning kit built ones http://www.modelaircraft.org/PDF-files/510-B.pdf http://www.modelaircraft.org/PDF-files/510-C.pdf http://www.modelaircraft.org/PDF-files/510-A.pdf |
RE: Frank Turbines
ORIGINAL: causeitflies ORIGINAL: AndyAndrews ORIGINAL: seanreit Andy, I'm not sure if you knew, but the AMA used to Certify turbines, and turbine manufacturers had to go through a process to become certified. Then it was dropped to any engine that is currently in production. I'm not current on all the rules associated with this, but I think even homebuilts now are allowed without certification, but don't quote me on this. Regardless, if the turbine is a manufactured product from a company that is at least partially in the business of building model turbines, you are AMA compliant. To a lawyer "approving" is "certifying" Once an agency approves something, they place themselves on the law suit chain. It's only going to get worse once Chairman and comrad Maubama gets in power. |
| All times are GMT -8. The time now is 10:20 AM. |
