RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Smoke question (https://www.rcuniverse.com/forum/rc-jets-120/8129537-smoke-question.html)
Zagzoo 11-09-2008 10:32 AM
Smoke question
How much smoke fuel do you carry and how long does it last? I was thinking 16-20 oz tank? I know it depends on how much you want to use it. Trying to get an idea for here and there use during flight.
thanks
Ehab 11-09-2008 12:21 PM
RE: Smoke question
I like a lot of smoke for a long time that's why they call me smoking Sam:). At least 28-40 oz is good for me(depends on airframe capacity for smoke). I use the Sullivan smoke system and it is great...
Molar mender 11-09-2008 12:53 PM
RE: Smoke question
1 Attachment(s)
My Big Boomer carries 24 oz and I built my own smoke system using an old turbine pump. My system uses an ESC to control the flow of smoke using a slider switch on the TX. A couple of clicks on the slider and I can have smoke the whole flight which is 8 min or I can go max flow on the slider switch and it will pump 8 oz a min so the tank will only last less than 3 min. The first couple of photos is light, the rest are heavy.
Roy
Wayne22 11-09-2008 09:13 PM
RE: Smoke question
What? No smiley faces, Roy???
I burn 10 to 11 ounces per minute full on...
http://www.youtube.com/watch?v=YmRfMDzl-Wo
I have 6 tanks stuffed inside that F-16, but only two of them are for smoke....
Hammbone 11-09-2008 10:31 PM
RE: Smoke question
48 ozs is gone in about 4 to 5 minutes with me.
Jim
bcovish 11-09-2008 11:20 PM
RE: Smoke question
1 Attachment(s)
ORIGINAL: Hammbone
Jim
Same here
Ehab 11-10-2008 07:40 AM
RE: Smoke question
Any one has a formula for mixing the proper fluids to get the best smoke? I have been using dry smoke and it is great, but now it is not available where I am at. I can get deisel, ATF and paraffin here. a mix ratio would be appreciated..
