Wheels needed!!!
I need a set of RC Jet wheels. I need a 2.5" nose and 3.75" Mains with brakes, where can I get a nice set cheap!! How neccesary are having brakes on a 20lb EDF. My field has a 150 runway so plenty of room to slow down. Thanks to all for your help.
RE: Wheels needed!!!
You really don't need them on a EDF plane. I could see if you were runing a turbine, But with a EDF just come in and use your elevator as a air brake. If that does not work you can put a o-ring on both side of the wheels and tighten them down a little tighter and that will make the wheel not roll as fast and it should slow down just fine. I hope you can use any of these things. Eric
| All times are GMT -8. The time now is 12:22 PM. |
