UAT with Festo
Hi Guy's:
Here is a question for you, I have the UAT with the festo's on them, I was told that they can bleed air into my system, I do not doubt this but have any of you run into this problem Thanks, Dave |
RE: UAT with Festo
Dave,
I have run them many times, never had a problem. If you don't push the tubes in all the way, you could have problems. Also, if you use the Festo clear line, you won't have any problems at all. If you use the Tygon, just make SURE its in well. Give it a good pull! |
RE: UAT with Festo
I agree with Chad...never had a problem
RE: UAT with Festo
Very good, thanks Guy's
Dave |
RE: UAT with Festo
ORIGINAL: WhoDaMan Hi Guy's: Here is a question for you, I have the UAT with the festo's on them, I was told that they can bleed air into my system, I do not doubt this but have any of you run into this problem Thanks, Dave You should never see a senario where you will have exceeded the - or + pressure rating for a festo fitting on a UAT. Alan |
| All times are GMT -8. The time now is 09:35 AM. |
