keroscene question....
I found a place here in Fairfield Ca that sells kerosene but it has a red dye added to it. Can i use it . cost $31.00 for 5 gallons the place is B Ramos Oil Co.
later Arden May |
RE: keroscene question....
ORIGINAL: A MAY I found a place here in Fairfield Ca that sells kerosene but it has a red dye added to it. Can i use it . cost $31.00 for 5 gallons the place is B Ramos Oil Co. later Arden May The short answer is YES, i have been using it for years now. it is all i can find at the pump. Alan |
I asked Bob Wilcox about this also. He said it is fine to run in Jetcat engines.
THANKS .... I will get some they also carry jet fuel but i think i will use the kero.......
Arden |
| All times are GMT -8. The time now is 11:42 AM. |
