bvm arf servo,s in tail
Anyone using DS3301 JR's on tail
RE: bvm arf servo,s in tail
Not sure if it's the same but Jason advised me to put 8411's on the elevator of my classic bandit and they arrived this morning. I can now get on with my install:D I just need to get some metal servo arms for them as the plastic ones suffered from the heat coming off the bypass/tube
It's designed around 3401's I have 9401's by opening the width and length a little.
3301's are not tight enough on the gears-MG servos are better. 8411 won't fit the ARF as they are in the tail unlike the classic/Super. Dw |
Arf...[:'(]
I have 9411's. it is a tight fit but I always thought that the 3301's are a little bit small.
My manual says 3421's for elevator in the Barf. The 3301's made me nervous in my Bobcats but they did hold up.
UK JR Numbering is slighly different from US servos...
I've had 8611a's in all my BARF's. I have to enlarge the opening right up to the wing skin, but they fit. Since I only put Titan's in my BARF's, I don't mess around with the jesus surfaces. ;)
Raf |
| All times are GMT -8. The time now is 10:05 PM. |
