JET CAT DATA CABLE QUESTION
I have found myself in need of a 42" data cable to go from the ECU to the turbine. Is this special wire or can I just go down and pick up a length of 6 wire phone cable? thanks for your help.
Ronald R Long |
RE: JET CAT DATA CABLE QUESTION
Ron, no, be careful, I understand it is NOT wired the same way as telephone cable, Gary.
Ron - this may help:
http://www.rcuniverse.com/forum/m_8091535/tm.htm Note the comments about making sure of polarity etc. |
Gary thank you and Gordon thanks for the link I will call Bob and order one or I will buy some stock cable and a set of crimpers and make my own.
Ron |
ORIGINAL: arizonasun25 I have found myself in need of a 42" data cable to go from the ECU to the turbine. Is this special wire or can I just go down and pick up a length of 6 wire phone cable? thanks for your help. Ronald R Long Les ORIGINAL: madmodelman Ron, no, be careful, I understand it is NOT wired the same way as telephone cable, Gary. For our purposes it doesn't matter how its wired, only that the colored wires are in the same location on each plug. Les |
Great thanks for the help Les I will make mine as well.
Ron |
| All times are GMT -8. The time now is 07:22 PM. |
