RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   BVM vs Dynamax starter wand (https://www.rcuniverse.com/forum/rc-jets-120/8549649-bvm-vs-dynamax-starter-wand.html)
turnnburn 03-06-2009 09:15 AM
I am told a BVM starter wand will work on a Dynamax rotor bolt and vice versa. I never knew that to be the case. Anybody recall if this is true or not ?
Hustler58 03-06-2009 10:02 AM
RE: BVM vs Dynamax starter wand
ORIGINAL: turnnburn
I have one and live by you if you want to try. Butch [email protected]
aquaskiman 03-06-2009 10:06 AM
Yes they will I have both
Kevin_W 03-06-2009 12:57 PM
Both the BVM and Dynamax fans use a 1/4" allen bolt for the probe to engage, so both manufacturer's probes have a 1/4" hex ball. The difference is in the diameter of the shaft of the starter probes.
The BVM probe is made out of 1/4" steel rod with brass tubing on the outside as a handle. I would guess the outside diameter is no more than 5/16".
The JMP probe is machined out of much larger stock which gives it a much larger outside diameter (I think it was bigger than 1/2").
The JMP probe is beefy and I doubt one of them has ever broken, and I think the ball ends are replaceable with a couple of screws.
The BVM probe has the ball end silver soldered into a brass sleeve, and they have been known to break as a result of improper starting technique. The ends can be replaced, but it requires a torch and silver solder.
The JMP probe could not be used on many BVM models because it was too large to fit through the access hole.
I made my own that were similar in design the the BVM one, but used 5/16" steel rod instead. I soldered the hex ball on with brass tubing, and threaded the other end so I could install a standard model spinner. It took less than an hour to make one, and it saved me a lot of money.
FalconWings 03-06-2009 02:26 PM
I only have an Avonds "Dynamax" probe and used it on both.
ECalderon 03-06-2009 02:27 PM
Hi guys.
For what its worth the BVM starter is also good for the Ramtec fan. It does break ocasionally but it is also a snap to fix. I dont use a torch and silver solder, I use thick CA.
Reagards
Eduardo
turnnburn 03-06-2009 03:24 PM
Thanks guys. The reason I asked was becasue I am selling a BVM probe to a guy who has a Dynamax fan. I didnt want to sell it to him if it wouldnt work. Sounds like we are good to go. I feel better knowing for sure.
bcovish 03-06-2009 03:45 PM
True
